Gear ratio??
Old Jul 28, 2005 | 10:57 AM
pauvil's Avatar
pauvil
Default Gear ratio??
anyway to tell the gearing in the rear, tag or anything, I know you can spin the wheels and count for a rough idea. 1975 l-48 with 400 trans.
Old Jul 28, 2005 | 11:04 AM
big_G's Avatar
big_G
I need the 2 letter code stamped on the bottom of the differential housing, adjacent to the strut rod bracket. AY=2:73, AW=3:08, AX or LR= 3:36, AA=3:35, AB=3:70, AC=4:11......
Old Jul 28, 2005 | 11:23 AM
pauvil's Avatar
pauvil
I will look tonight, thanks!!!
Old Jul 28, 2005 | 12:48 PM
GTR1999's Avatar
GTR1999
Unless it was changed I'll bet it's a 308 with that setup.
Gary
Old Jul 28, 2005 | 01:26 PM
pauvil's Avatar
pauvil
I did read somewhere that all the low horse L-48's were a 3:36 for that year, that's why I was wondering, I did throw a set of domed pistons in there to up the compression to 9.5:1, I'm changing the cam soon. I'm debating on headers and side pipes or just duals with the stock manifolds, we'll see.
Old Jul 28, 2005 | 02:22 PM
Fevre's Avatar
Fevre
To be sure jack the back end off the ground rotate the wheels one revolution and count the drive shaft rotation, if 3 then 3.08, if 3 1/3 the 3.36, if 3.75 then 3.70 etc.
Old Jul 28, 2005 | 02:34 PM
72Tornado's Avatar
72Tornado
Given that it's kind of hard to tell if the driveshaft rotates 3.08 times or 3.36 times, I'd recommend rotating the wheels 10 revolutions instead
Old Jul 28, 2005 | 02:47 PM
Fevre's Avatar
Fevre
I can't count that high.
Old Jul 28, 2005 | 03:01 PM
CGGorman's Avatar
CGGorman
Originally Posted by gtr1999
Unless it was changed...
In other words, trust nothing but the indisputable. Count either the teeth or the revs.
Old Jul 28, 2005 | 04:17 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
He cant count that high either
Old Jul 28, 2005 | 04:27 PM
big_G's Avatar
big_G
Put 4:11's in it and call it a day.
Old Jul 28, 2005 | 05:02 PM
CGGorman's Avatar
CGGorman
Originally Posted by big_G
Put 4:11's and a TKO-600 in it and call it a day.
Old Jul 28, 2005 | 11:06 PM
Mike Mercury's Avatar
Mike Mercury
an old rule-of-thumb to determine rear axle ratios was to take the car up to 75mph with the tranny in a gear that's a 1:1 ratio. 4 speeds this was 4th gear, and automatics it was 3 "D".
then divide the RPM by 1000. You must be using the same rear tire heigth as what originally came on the car (or have a corrected speedo if rear tire heigth was not original).
examples:
3080 RPM would mean a 3.08 rear axle ratio.
3700 rpm would equate to a 3.70 rear ratio.
automatics with non-locking TC's tend to mess this test up a bit; the RPM would be a little higher than it should be. (300 to 400 rpm ???)
I haven't tried this on a C3 in many... MANY years. I don't know how valid it is today - across the entire automotive spectrum.
Old Jul 28, 2005 | 11:54 PM
jdmick's Avatar
jdmick
I think that may be pretty close Mr. Mercury.
Pauvil, does your acceleration really suck? Chances are you've got a 2.73 like my 75 had. If you're revving under 3,000 RPM at 75 MPH like Mike says that's would be a good guess. Do you have more than 50K miles? Chances are the side yokes are shot. You can rebuild it with different gears if your case isn't toast ($$$$) or find a different one like I did with better gears (3.36 at least).
Old Jul 29, 2005 | 12:00 AM
rihwoods's Avatar
rihwoods
At 70 I'm reving almost 3500....I know what I got...3.70:1
Old Jul 29, 2005 | 12:24 AM
Retro78's Avatar
Retro78
Assuming that you have a 255/60/15 rear tire and your tach/spedo is accurate you have 3.91..not 3.70
Old Jul 29, 2005 | 03:51 PM
7t5's Avatar
7t5
St. Jude Donor '14
My owners manual says an l48 auto had a choice of 2.73(Econ.) or 3.08 (Std). No other choices were listed for this combo. Page 77 of the 1975 owners manual.
Old Jul 31, 2005 | 01:52 PM
pauvil's Avatar
pauvil
The car has 38,000 original miles, I'm the third owner. I haven't driven it yet, I just like to know what I'm working with so when it does fall on it's face with the joke hp this year makes I can determine the cam I'm going to use. I've already put 9.5:1 domed pistons in. I don't see a cast on the differential either.
To Gear ratio??
