Surprise find
Old Jul 28, 2005 | 03:04 PM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default Surprise find - special suspension
About a year ago, someone made a post about a lady from GM that would send you a copy of the window stick for your specific vette. All you had to do is send her you VIN. I go it, illaminated it, and then set it aside. I wanted it for documentation but never really looked it over carefully. Well, I was studying it the other day and I was going over the options. I found out that I have a gymkhana suspension.
What is the difference between this option and the stock suspension? I plan on redoing all of that underneath, but would like to keep it gymkhana if possible since I want to keep it all stock.
Old Jul 28, 2005 | 03:22 PM
SomeSayIllFixIt's Avatar
SomeSayIllFixIt
You have a significantly stiffer suspension than stock. I believe that it was intended mostly for racing. However, I cannot give you exact spring rates off the top of my head.
Old Jul 28, 2005 | 03:37 PM
LOTAHP's Avatar
LOTAHP
Yes, there was a guy named Jim Conner that use to road race Corvettes and it's named after him.
Old Jul 28, 2005 | 03:47 PM
NHvette's Avatar
NHvette
Option FE7
I think it has the 7 leaf steel spring and higher rate (maybe 460) front coils.
Not sure about sway bars.
The rear spring is 2 1/4" - with two steel spacers to fill the
2 1/2" space used for standard springs.
... just openned my resto guide:
Front sway bar is 1.12", rear sway bar at 9/16".
Old Jul 28, 2005 | 04:22 PM
jonny4523's Avatar
jonny4523
Originally Posted by NHvette
Option FE7
If you buy a suspension rebuild kit (bushings, ball joints, tie rods), will they be the same as the ones that came with it? Just as long as I don't replace the springs and sway bars right?
Old Jul 28, 2005 | 04:56 PM
PRNDL's Avatar
PRNDL
I thought his name was Jim Kahuna !!!
(see related post, re "Jim Kahuna" suspension! )
Old Jul 28, 2005 | 04:59 PM
CGGorman's Avatar
CGGorman
I would call VBP and ask them. My guess would be that all the tie rods and balljoints would be identical. Bushings should all be identical except the ones for the sway bars since they have a lerger diameter. (my chassis engineer friend insists that I call them either "stabilizer bars", "sta-bars", or "anti-sway bars").
Old Jul 28, 2005 | 05:28 PM
fl_rider's Avatar
fl_rider
Default gymkhana
gym·kha·na ( P ) Pronunciation Key (jm-kän)
n.
1. Any of various meets at which contests are held to test the skill of the competitors, as in equestrianship, gymnastics, or sports car racing.
2. The place where such an event is held.
[Probably alteration (influenced by gymnastics), of Hindi ged-khn, racket court ged, ball (of Dravidian origin) + khn, house (from Persian khna, variant of khn. See khan2).]
Old Jul 28, 2005 | 05:36 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I think I have one of those Jim Conner suspensions too. At least, that's the signature on my leaf springs.
Dep
Old Jul 28, 2005 | 06:14 PM
rihwoods's Avatar
rihwoods
signature springs....
To Surprise find
