Side pipes SS VS Chrome?
Old Jul 28, 2005 | 07:44 PM
KillerBee's Avatar
KillerBee
4th Gear
Default Side pipes SS VS Chrome?
Hey guys, new to the vette scene.
What I have is a 69 T-top I got with a blown up rear end. So in the process of getting that fixed I tore out the old crushed and rusty pipes from under the car. (rear exhaust)
Now I like the look of the Hooker header and side pipe setup.
So far I haven't seen any info on the stainless steel VS. chrome plated steel.
My concern is that the stainless steel will most likely turn brown, or that the chrome will rust. Since I have no experiance with either I am looking for input here. These things aren't cheap, am I'm not made of money so I only want to have to buy the stuff once.
Also input on the mufflers would be good too.
Any and all advice will be mucho appreciated.
Old Jul 28, 2005 | 08:11 PM
75 Stingray!'s Avatar
75 Stingray!
Next time I'm going with SS
Don't use the hooker mufflers you will loose power
I've got THESE recently, they sound good but I don't have much seat time with them yet.
Old Jul 28, 2005 | 10:11 PM
SteveG75's Avatar
SteveG75
Agree with the Spiral Turbo baffles. I thing the question should be Stainless or Jet Hoat coated. The Hooker ceramic coating is junk. I have the Jet Hoat coated ones in their Sterling finish. Check my pictures.
Old Jul 28, 2005 | 10:19 PM
Corey_68's Avatar
Corey_68
Given those two choices you must want something that shines.
So that means the Jet hot is out even the "Sterling Finish". While the Sterling is MUCH improved over the base Jet coat is too looks dull when compared to chrome. This in't bad on a rubber nose shark, but on a chrome bumper it stands out as a contrast the the shiney bumpers. The chrome looks the best, but will rust and tarnish over time, the SS will last.
Personally I rather get the pipes re-finshed every 10years than to have a somewhat dull set of pipes.
Nothing like a chome set IMO.
Old Jul 28, 2005 | 11:25 PM
GasketDude's Avatar
GasketDude
This is the big debate that's been going on here for awhile. I went with the S/S myself... mine is a work in progress still. But with previous experience with (JetHot) coated parts they will dull alot over time. The S/S may discolor at the heads but should not at the sides if your "tuned" right. Others have mentioned that S/S retains heat more = more chance for permanent leg burns. My polished set look just like chrome, maybe just a tint darker than a fresh chrome job. And they'll stay that way for life (?)
Spend the money, if your going to keep the car for any length of time, it'll be worth it. I think you can barely see just the headers in one of my overall pics.
Later.
Old Jul 28, 2005 | 11:26 PM
rosslato's Avatar
rosslato
Ditto. love chrome, but not on my hookers ever again, jet hot for me. and the Spiral Turbo baffles sound great
Old Jul 28, 2005 | 11:33 PM
KillerBee's Avatar
KillerBee
4th Gear
I agree with the shiny bumper matching the pipes!
I didn't see the "Sterling Finish" yet. Still looking at options.
Now I see from this: http://www.corvettefever.com/howto/4680/
That the AC bracket has to be ground down a bunch.
Anyone know if a revised bracket is available?
Or do I just grind on the original bracket?
Me thinks a good idea would be to save the original bracket and geta new one that fits better, but where??????
Thanks for the input !!
Old Jul 28, 2005 | 11:59 PM
Corey_68's Avatar
Corey_68
Steve has the sterling finish on his Yellow vert, see a couple posts up.
Old Jul 29, 2005 | 05:10 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
If I would have had the option, I would have gone with stainless, here's Jet-Hot's Sterling finish...
Old Jul 29, 2005 | 07:07 PM
bren's Avatar
bren
I am thinking of Replacing my GM side exhaust and getting hookers for my '74. I notice some seem to hang to low and some look perfect like above . Is it the way they installed it.
Old Jul 29, 2005 | 07:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
stainless - keep in mind that you may have to dent one of the primary pipes to clear the steering box. I don't know if that is "normal" but I needed at least 1/8" additional clearance between the primary tube and the steering box. If I had ordered chrome or coated I would have send the header back because the coating would have chipped off....
Mufflers ? I have "sweet thunder" 2 1/4" mufflers, they're $170 incl. shipping - not installed yet.
Old Oct 16, 2005 | 01:03 PM
wnjlt1's Avatar
wnjlt1
I went with stainless hookers per forum member suggestions. Had no install issues. Just a little yellowish discoloration where the pipes/ header flange are attached to the cylinder heads. I also went with Sweet Thunders 2 1/2.......they are loud but I love it that way.
Old Oct 16, 2005 | 01:10 PM
Rock80's Avatar
Rock80
Default How do the sidepipes mount on an 1980
What holds the sidepipes along the length of the car? Do you have to drill holes in the body? Remeber this is an 80 I'm talk'n 'bout! Any recommendations on headers and pipes? Where's the best place online to purchase?
JOHN
Old Oct 16, 2005 | 01:51 PM
startwith80vette's Avatar
startwith80vette
for an 80 jsut take off the rocker panel running along the side of the car, there are holes in the frame that the pipes mount to. The pipes have tabs to bolt to these holes
and dont order online, give jethot a call, and tell them you are a corvette forum member, pretty nice discount. theya re very helpful and they give an amazing guarantee
Old Oct 16, 2005 | 06:57 PM
Red73's Avatar
Red73
I went with chrome a couple of years ago, I would of purchased the stainless if they were available at that time. Rod
Old Oct 16, 2005 | 07:35 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I went with chrome.Mine are like 15 years old and they still look good from 10 feet.
To Side pipes SS VS Chrome?
