Ps Problem
Old Aug 1, 2005 | 09:19 AM
vete76's Avatar
vete76
Default Ps Problem
i just replaced everything in my ps. serviced it with ps fluid.
now when i drive it and just barely turn right it wants to rip it out of my hand and turn hard right. whats wrong?
thanks
fred
Old Aug 1, 2005 | 10:38 AM
adamdinat's Avatar
adamdinat
Sounds like you need to adjust the control valve. You will find some good instuctions at www.corvettefaq.com
Old Aug 1, 2005 | 11:40 AM
vete76's Avatar
vete76
I went there but only found instructions for rebuild and what to do if it leaks.
did i miss something?
thanks for your promt reply! there is a wealth of info there i will use on other matters. thanks very much!!!
Old Aug 3, 2005 | 11:14 PM
vete76's Avatar
vete76
ttt
Old Aug 4, 2005 | 01:06 AM
Tall Boy's Avatar
Tall Boy
It might be airlocked?
Old Aug 4, 2005 | 01:58 AM
rihwoods's Avatar
rihwoods
Tall Boy may have a point....Also....I let a dummy install a control valve and he did not adjust it..blew a pressure hose right out the fitting....
suggest you get it in the air, start engine with steering wheel centered..if valve is out of adjustment,the steering wheel will go left or right..if not,then purge air out...Chiltons Corvette repair manual section 8-38.
For valve balance:
http://www.corvettefaq.com/c3/ValveR...ance18AP05.doc
Rich
Old Aug 8, 2005 | 02:03 PM
vete76's Avatar
vete76
For valve balance:
Rich
taaadaaa! perfect help. took 3 min to adjust and car steers perfect!!!!! many thanks!!!!!!!!!
To Ps Problem
