trip meter reset
Old Aug 4, 2005 | 06:28 AM
carl a's Avatar
carl a
Default trip meter reset
just was wondering how many have a trip meter that will not reset, or very hard to reset?- these cable driven resets were used on 1963 thru 1977 corvettes thanks carl------------------
Old Aug 4, 2005 | 06:46 AM
PhotoVette1's Avatar
PhotoVette1
My trip odometer was a real PITA until I replaced the black plastic **** on the end--evidently it was stripped and slipping. Ecklers has'em.
Old Aug 4, 2005 | 07:30 AM
norvalwilhelm's Avatar
norvalwilhelm
My rubber **** was also bad so I replaced it with a brass one I made myself. I also used WD40 and really sprayed up the stem alot. It now works smooth and easy.
Old Aug 4, 2005 | 08:02 AM
second76's Avatar
second76
My trip meter was working when I bought the car, less than a year ago. Then, I tried to reset it. It did not reset and now the trip meter is stuck.
Old Aug 4, 2005 | 08:51 AM
Pete76Shark's Avatar
Pete76Shark
Mine is stuck and will not push in anymore. Not sure when this started as it did work at one time for me. Since I dont use it I have not bothered to fix it.
Old Aug 4, 2005 | 09:09 AM
LYLE's Avatar
LYLE
After you push them up to reset make sure you pull the **** back down or the trip mileage won't work.
Old Aug 4, 2005 | 10:11 AM
mrtroutjedi's Avatar
mrtroutjedi
ive looked for mine and can't find it so Im pretty shure that I don't even have the cable anymore
Old Aug 4, 2005 | 10:27 AM
SR7D1's Avatar
SR7D1
Mine is hard to operate and the little rubber cap fell off in my hands last time I tried. I will try lubing it up, how do you get to it to oil it?
I'd like to have it to gauge mileage or how far I have gone so I can fill up without running out of gas. The fuel gauge works but I don't know "how" emply "E" is.
Old Aug 4, 2005 | 11:20 AM
CGGorman's Avatar
CGGorman
Works fine now that I removed it from the gauge, cleaned/lubed it, straightened a kink in the sheath, built a bracket to hold the stem, and finally reinstalled it on the gauge. Haven't used it since.
Old Aug 4, 2005 | 01:01 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
mine won't work either, and if I mess with it, it takes me a while to get the normal odometer to work again. I would sure like to use it for inbetween fillups though. Maybe I'll play with it after I mess with my overheating
Old Aug 4, 2005 | 01:51 PM
tigers123's Avatar
tigers123
Default autometer
One of the reasons I'm changing all my instruments. Big time speedometer and tach needle bounce. Half the gauges in the center console are also on the fritz. Cars this old will have these problems. I'm not ncrs bound so I will have my creature comforts instead of putting up with cranky 30 plus [years] stuff. Trip odometer built right into the autometer speedometer. Plus a change in looks on the dash might be a little more pleasant.
Old Aug 4, 2005 | 04:43 PM
71rdster's Avatar
71rdster
Default Autometer
I will be wanting to see pictures of your Autometer gauge installation.
Orville
Old Aug 5, 2005 | 09:02 AM
ruby76's Avatar
ruby76
Orville
Me too, me too!
Old Aug 5, 2005 | 10:22 AM
CGGorman's Avatar
CGGorman
I kinda like the rickety old gauges. They make the nostalic feel of the car more "real" since though I've got lots of other modern modifications to help drivability and comfort. I was kinda sad to let go of the Delco tick-tock clock, but the Quartz conversion was singin so sweetly in my ear... :o
Old Aug 5, 2005 | 10:57 AM
RC73's Avatar
RC73
What model number did you get? I went to their web site, but did not see one for c3's?
To trip meter reset
