weight
Aug 6, 2005 | 10:12 PM
weight
does any one know what is the weight of a stock 78 corvette?
thank you
Aug 6, 2005 | 10:21 PM
does any one know the weight difference of this items
aluminium heads Vs stock
aluminium intake manifold Vs stock
aluminium water pump Vs stock
thank you
Aug 6, 2005 | 10:55 PM
Great questions. I have pulled about 150lbs out of my 78 by installing seats from an 80, removing many of the heavy brackets behind the bumpers and a lot of misc small items like removing cruise controls, Air Con... I will be installing Alum heads, Water pump and converting to a T5 trany this winter but no idea how much weight they save.
Aug 6, 2005 | 11:05 PM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The closest I can come up with as far as car weight is
1. 1977-3540 lbs
2. 1979-3655
I would guess that the 78 is right in there pretty close.
Aug 7, 2005 | 12:05 AM
From: The Armpit of Illinois Platato says..... "Sometimes your the windshield & sometimes your the bug".
St. Jude Donor '05
I know this is a dumb question but did you check the sticker on your drivers side door jam?
STW!
Platato
Aug 7, 2005 | 12:19 AM
Quote:
STW!
Platato
there is no sticker on my door jam
Aug 7, 2005 | 12:32 AM
No sticker here either. Just found several references on the web... a 78 has a curb Weight of 3,572 lbs
Aug 7, 2005 | 03:49 AM
Quote:
I thought it was allot lighter then that
I guess is time to make it ligher
Aug 7, 2005 | 03:50 AM
Aug 7, 2005 | 03:52 AM
I already took the A/C + heater, sparetire + tub, and jack out of the car
Aug 7, 2005 | 06:22 AM
The reference I looked at said 3500...
Chris B
Aug 7, 2005 | 09:23 AM
Quote:
1. 1977-3540 lbs
2. 1979-3655
I got this info out of an old Road And Track compilation book. Never a corvettes friend.
Aug 8, 2005 | 03:42 PM
Weighed my '76 last year. 3450# with me in it. Aluminum heads, intake, wheels, and headers. Full tank of gas. So I would say <3300# curb.
Aug 8, 2005 | 03:54 PM
The Corvette Black Book lists the curb weights as:
1977 - 3541#
1978 - 3572#
1979 - 3503#
GUSTO
Aug 8, 2005 | 04:46 PM
The correct answer is: TOO DAMN HEAVY.
