brake runout
Old Aug 7, 2005 | 01:25 PM
mike 78's Avatar
mike 78
4th Gear
Default brake runout
How do you check the runout on your brakes
Old Aug 7, 2005 | 04:13 PM
big_G's Avatar
big_G
I use a magnetic base dial indicator. Clamp it on the trailing arm, and set the pointer about 1/2 in from the rotor edge. Don't forget to install the 5 lug nuts and torque them to 85 lb/ft. Rotate the rotor at least 2 times to get a good reading. The spec. is <.004 in. runout...G/L
Old Aug 7, 2005 | 04:44 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
To brake runout
