70 positraction question
Old Aug 10, 2005 | 08:19 AM
cosmicvette's Avatar
cosmicvette
Default 70 positraction question
I know Positration was included in the Base price of 70 vettes...so does that mean that all 70 vettes had positraction? or was there a delete option? and if there was a delete option, does anyone know how many chose not to have positraction?
Was there a standard ratio?
(my bf and I just went and checked the numbers on our diff, and when we looked at the prefix it suggested we didn't have positration..and we were shocked! -but we didn't see the code clearly enough...and we are too stressed to go jack the car up and check if both wheels turn to see if it has positration - oh and its too cold - might try in the morning).
Thanks for your help.
Old Aug 10, 2005 | 09:50 AM
yellow72's Avatar
yellow72
according to vette set there is 1 diff that was not posi (3.36 gear), the prefix is CAK, all other stock diffs have posi and range from 2.73 to 4.56
Old Aug 10, 2005 | 09:58 AM
70Donnybrooke's Avatar
70Donnybrooke
Thats not true. A 3.36 in a 70 was the performance axel ratio. I have it in mine. I also have the positraction warning sticker in the jack box. Also, when the car is lifted both wheels spin in the same direction.
Old Aug 10, 2005 | 10:06 AM
cosmicvette
Im going to test it out in the morning and work out the ratio and see what Ive got! (hopefully Ive still got the original diff).
Stay cool
Old Aug 10, 2005 | 10:12 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I have 3:36's too and its a posi. Black Book states posi's stock from 1970+
Old Aug 10, 2005 | 10:20 AM
big_G's Avatar
big_G
According to NCRS spec. guide, the following codes for 1970, and late 69, were standard, (not posi) : CAK, CAL, CAN, CAP, CAS, CAV, CAW, CLR...These include ratios: 3.08, 3.36, 3.55, 3.70, 4.11......
Old Aug 10, 2005 | 10:28 AM
cosmicvette
....yeah...thats what that 'Corvette by Numbers' book said.
So thats why Im asking....Positraction became standard (with the base model) in 1970....but if there are codes for standard (not positraction) diffs then does that mean there was a delete option or something? Im confused (I think I need to go to bed now...
Old Aug 10, 2005 | 10:41 AM
Z-man's Avatar
Z-man
That word "standard" refers to the ratios. All Vettes from '69 on have positraction.
Old Aug 10, 2005 | 10:47 AM
big_G's Avatar
big_G
The codes I listed shows that some diffs. may be non-posi......Just read the 3 letter code on your diff., and if it has not been gone into, then you now know what you have is original....posi or standard...NCRS agrees that they SHOULD all be Posi, but documentation shows a conflict with GM...
Old Aug 10, 2005 | 05:27 PM
Techno's Avatar
Techno
Even if it was a delete option I would doubt it would ever get used.
Who would delete posi to save $50 bucks?
I'm wondering how rare base corvettes are in any year. You know, no options at all.
Old Aug 10, 2005 | 05:39 PM
GTR1999's Avatar
GTR1999
light up the tires a take a look behind
Old Aug 10, 2005 | 06:49 PM
cosmicvette
All should be standard but documentation shows a conflict with GM...?
I am still confused.
Ofcourse, I will have a look at my vette today...but I am interested as to this conflicting documentation and that all 70's came with positraction as standard (well all vettes from 70 onwards - and basically 69 - as nearly all 69 vettes had the positraction option).
Is it as Z-man said? That the word 'standard' in the documentation refers to standard ratios (as opposed to the opptional ratios)?
Now that starts to make sense...
Old Aug 10, 2005 | 09:36 PM
big_G's Avatar
big_G
The NCRS numbers manual shows 2 letter codes for each axle ratio...1 for posi, 1 for standard...except the 4.56 units..I believe the conflict is that GM issued the 3 letter codes for non-posi units for 1970, but cannot be confirmed to be actually put into service...
Old Aug 10, 2005 | 11:17 PM
Techno's Avatar
Techno
Old Aug 11, 2005 | 01:03 AM
cosmicvette
Id love to be able to!!!!!!!!!!!!! .....BUT .....
my vette isn't running properly....its bloody hesitating on acceleration at low rpm...and if you put your foot down a bit it stalls.
(its an auto).
I thought maybe it was the accererator pump (cause it had been sitting for 4 months) but now Im thinking ignition system - Spark Plugs is the first thing Im going to check/change. there is a noticable difference in the feel if you put your hand at the exit of one exhaust pipe compared to the other ...so that Im hoping is spark plugs ... (or leads/wires)
...spark plugs are not that easy to change on these cars are they!! (I got a shock when I had a look the first time)
Old Aug 11, 2005 | 01:54 AM
Z-man's Avatar
Z-man
The final answer:
I was wrong!! :o (A first... )
Check this out, from the Z-man files...
I thought I had read somewhere that all '70s were posies. Here's what mine looks like - 2CAM 3 26 70 W. That's the 3.36:1, March 26, 1970 Warren - positraction. That's about a month before the car assembly date.
Old Aug 11, 2005 | 05:30 PM
Techno's Avatar
Techno
Take into a parking lot or some place with plenty of room Floor it in a turn. Like your turing onto a side street. It will break the wheels loose. just straighten the wheels and look at the marks.
Old Aug 11, 2005 | 06:16 PM
cosmicvette
Id love to be able to do that...BUT my vette isn't running properly at all....it is really hesitating at low RPM's and stalls if you put the accelerator down.
I changed the spark plugs last night ....what a bloody nighmare they are to change! and so my bf and I after perservering were getting excited to test it out....and it was way worse!
I really can't handle this. I was so excited getting my vette - the inspection said it drove well ...so I wonder if the inspection place were being helpful to the seller! (but I wouldn't have thought so). Im pissed off
We might be taking it to a mechanic.....
Old Aug 11, 2005 | 08:02 PM
Z-man's Avatar
Z-man
Since it was such a long journey, there could have been some things go wrong during the trip. Hesitation could be a number of things. Is the accelerator pump on the carb working properly - i.e. when you open the throttle, do you see a good sized shot of gas going in? Are all the vacuum lines hooked up an tight? No leaks around the carb - is it good and snug?
Good luck - we'll get you going!
To 70 positraction question
