C3 disk brake interference with Cragar SS
Old Aug 12, 2005 | 01:36 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Default C3 disk brake interference with Cragar SS
I have a 63 custom but am converting it to disk brakes with C3 spindle assemblies and C3 trailing arms I should have the same clearances as a C3. Wondering if anyone knows the maximum backspacing you can run on a 15" Cragar SS and if wheel spacers are required to clear the calipers. If so are longer wheel studs also required?
Old Aug 12, 2005 | 07:22 AM
vetteonr's Avatar
vetteonr
I have 15x8 cragars on my '80 with a 4.5" backspace and a 1/2" spacer to clear the caliper. I did not have to get longer studs. This combo has worked well for me.
Old Aug 12, 2005 | 07:34 AM
GDaina's Avatar
GDaina
Same thread in Tech.
To C3 disk brake interference with Cragar SS
