T top straps - ?? - [PICS]
Old Aug 23, 2005 | 07:52 AM
70Donnybrooke's Avatar
70Donnybrooke
Originally Posted by cosmicvette
Really? Where/how are your seat belts located?
Are mine incorrect? have they been bubbafied????
This is how mine are. My car is a late 70. I never seen one like yours. That is an long way from back there to click into the front belt.
Old Aug 23, 2005 | 07:35 PM
cosmicvette's Avatar
cosmicvette
Thanks for your reply and for posting the pic.
Yeah my seatbelt is mounted differently to yours. I looked in the AIM and as far as I can tell yours is correct and mine seems to be incorrect.
However, who would go changing the mounting place????
Im hoping mine is correct for an early 70 vette....can anyone confirm if mine are correct or incorrect?> (maybe I should start a new thread)
Cheers!
Old Aug 23, 2005 | 09:41 PM
Sandiego70's Avatar
Sandiego70
Those are just like mine, but has anyone put t-tops in with straps?
Old Aug 24, 2005 | 07:39 AM
cosmicvette
Which ones are like yours? Donnybrooks or mine?
and Nope, haven't tried putting the T-tops in with the straps yet....need to get some bags then I will give it a go!
Old Aug 24, 2005 | 11:09 PM
Sandiego70's Avatar
Sandiego70
Donnybrooks the pair of single straps matching the interior, I am pretty sure mine are original on my 70.
Old Aug 24, 2005 | 11:11 PM
cosmicvette
My T top straps are the same - the two single straps for 70....but I was referring to the seatbelt set up for the retractors in the rear.
I probably should start a new thread so as not to confuse issues. !
Old Aug 24, 2005 | 11:24 PM
Sandiego70's Avatar
Sandiego70
Donnybrooks seat belt retractors are set up like mine, I do have original 70 seat belts.
Old Aug 16, 2019 | 07:32 PM
Philgran's Avatar
Philgran
I just tecarpeted my '79. I have acY-Strap to hold down the tops. Forgot to beasure where the brackets were before I took them off the old carpet. A rookie mistake. Can anyone tell me where the brackets should go? Pictures would help greatly! Thank you!
Old Aug 16, 2019 | 08:46 PM
Tom73's Avatar
Tom73
How do these 14 year old threads keep coming back to life?
Old Aug 16, 2019 | 08:52 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Google any thing to do with corvettes and the forum comes up most of the time and it could be a new thread or a 14 year old thread ,its not fussy
Old Aug 16, 2019 | 08:54 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
IMHO, they need to be closed after a certain amount of time.
Old Aug 16, 2019 | 09:26 PM
interpon's Avatar
interpon
Here is my 79
Might get more replies if you started new thread..good luck
Old Aug 29, 2019 | 02:04 PM
  #33
Philgran's Avatar
Philgran
Thanks for the photo, measured a 73 at a car show. Tried to find the original holes with an awl. No luck. I used the measurement I got at the show and drilled new hole and put them in. They look OK and work fine. Half the people I talked to st the show had no idea what they were for.
For those members whose tie-down straps had faded from the sun, I think I came up with a solution. I was thinking unable to find a RIT dye color that matched my color (red) so I went to a hobby store and bought "fabric paint" in the correct color. Looks great!
Old Aug 30, 2019 | 02:11 AM
  #34
AB_in_AUS's Avatar
AB_in_AUS
on my 79 the original holes go all the way into the wheel well, you can push a wire up from the bottom. I used an old coat hanger with the end sharpened to point .. one you have one side of the bracket in its pretty easy to find the other with the awl
Old Sep 3, 2019 | 04:48 PM
  #35
Philgran's Avatar
Philgran
Thanks, all set!
Old Sep 4, 2019 | 04:50 AM
  #36
brit vet's Avatar
brit vet
2024 C3 of the Year Finalist- Unmodified
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
The related thread function. You can turn it off to prevent Zombi threads
