Building headers
Old Aug 17, 2005 | 09:19 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Building headers
Where is a good place to buy some 1 7/8" pipe bends? Speedway seems like a deal, $79 for a box of bent pipes.
Old Aug 17, 2005 | 09:39 AM
Dalannex's Avatar
Dalannex
Sounds like if you founds somewhere at all to find something like that you're doing good. What are you up to now? Can't find any headers that have huge primaries and fit a C3 with and LS1????? How's the car been running? What are you going with for the rest of the exhaust system?
-Justin
Old Aug 17, 2005 | 09:42 AM
RobRace10's Avatar
RobRace10
You can try Headers By Ed. Lots of components.
Headers By Ed
Old Aug 17, 2005 | 10:41 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
-Justin
Actually the ports are a 1/4" smaller, but why not build for the future. Forced induction...... Finding headers with the right spacing was the trick. I couldn't stomach cutting up a $1000 set of Kooks, so the best chose was to find a set of slightly used BB headers. They are already close, they just need to be moved out on the ends 1/2".
The plan is to run 2 1/2" pipe to Flowtec's or existing mufflers with QTP cut-outs set up by a MSD switch. We'll see how that works.
The vette is running fine, no issues at all since start up. Probably the best swap out there in my opinion.
Old Aug 17, 2005 | 10:43 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Headers By Ed
$21 to $40 per bent section. To rich for my blood. Thanks for the link, lots of good info.
Old Aug 17, 2005 | 03:08 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Ed has LOTS of good info, but he's not cheap. Speedway usually has good prices.
I built a set of side exit headers a few years ago, swore I'd never do it again. It harder that I thought! Of course getting 4 36" long 1 3/4" pipes intothat small of an area was part of the problem, looks like a basket of snakes...
Old Aug 17, 2005 | 04:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Can't be easy, even Hooker can't make them fit without dinging them
Old Aug 17, 2005 | 04:41 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
After looking at a set of Linkenfelter headers on a GTO, I'm hoping it looks that easy. I'm only going to tack weld them, someone with experience will Tig them. I know my limitations.
Old Aug 17, 2005 | 05:05 PM
Techno's Avatar
Techno
Not to tell you your business but if I was building my own headers I would contact headers by ed or someone else who knows the stuff.
Tell them what you have and they'll tell you what headers to build. Just choosing a pipe diameter and length isn't going to get you all that you can be
If your going to add or modify just build them for the final result. If just guessing rolling your own will probably be harder more expensive and possibly worse than store bought.
The headers by ed info seems to say going too large is a dead end. There is a limit since diameter of a circle adds enormously to area of a circle. A 1/4" step is much more at 2" than it is at 1.5".
For the $30? bucks it seems a worthwhile service.
Old Aug 17, 2005 | 05:51 PM
BigBlockk's Avatar
BigBlockk
Try here.
http://www.jegs.com/cgi-bin/ncommerc...27&prmenbr=361
BigBlockk
Later.....
Old Aug 17, 2005 | 08:35 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Why is building headers a general topic?
Old Aug 17, 2005 | 10:36 PM
1980 454's Avatar
1980 454
look at the welding web .com under projects theres a guy with plans for a bender for free.
Old Aug 18, 2005 | 10:38 AM
Glenn"Mr.Blue"Smith's Avatar
Glenn"Mr.Blue"Smith
From: Edgewater (20 miles south of Daytona) Florida
Here is an ad from the latest issue of Popular Hot Rodding Oct.'05 about oval pipe kits. Might look into that for added ground clearance. They say they have all you will need. Just trying to help. Glenn
Old Aug 18, 2005 | 11:01 AM
Twin_Turbo's Avatar
Twin_Turbo
oval elbows...just what I need...burns has them also, maybe spintech is cheaper.
To Building headers
