Man i'm having zero luck with vendors
-----Original Message-----
Sent: Wednesday, August 17, 2005 7:09 PM
To: 'tech@vbandp.com'
Subject: attn: Vette Brakes
I just received the rebuilt;
1. Power steering control valve
2. Power steering cylinder
My order number is xxxxxxxxxxxx
Okay the problems. One when the parts came in they were wrapped in plastic, when removing the plastic the paint came off with it. Some of the paint had actually liquefied and dripped out of the box (you’ll see this when you get the box of cores) So instead of being able to install the parts the first 2 days was scrubbing off the bubbled paint and re-painting/ drying time. Call me crazy but it seems llogical to paint power steering products with paint that withstands power steering fluid. I used gloss black Rustoliem and it will hold up to the PS fluid. Two when I installed the cylinder it leaked out around the extend hose. So I tried retightening/ Teflon tape etc. and then went and ordered a new hose for $24. Well the new hose also leaks same way. So I wasted $24 dollars If you look into the hole where the extend hose goes into the cylinder you see the sealing connection is not smooth, this is the problem. Which brings me to my question where your website reads “these parts have been pressure tested, which explains the power steering fluid and molten paint on the parts, however it couldn’t have passed any leak inspection due to the scratched sealing surface.
Now I do understand chances are you outsource to a third party to rebuild and pressure test these units so this e-mail is not a slight on you but something I request you pass onto them.
I also request another rebuilt PS cylinder be sent to me. The control valve is holding up so far and I commend you on that. If you need extra money and will refund me when I take off the leaking cylinder call me on the above number or my CC number. I want to keep my car on the road until the new (rebuilt) part arrives.
R/
David Oakey
(xxx) xxx-xxxx
Sent: Wednesday, August 17, 2005 7:17 PM
To: 'mail@corvettecentral.com'
Subject: INVOICE NUMBER xxxxxxxxx-xxxx
I just received part number 562302 which purportedly is the extend hose leaving the power steering control valve to the power steering cylinder. Well the pre-existing hoses on the car are GM originals and both are identical in shape and size. Your catalog shows 2 part numbers 562302 and 562303 and I ordered based on your diagram. Well it turns out regardless of which ever I place the hose, i.e. in return or extend it is 2 inches too long. I have it on the car now but it hangs way down and I had to bend the rubber section to allow it to fit (it’s too long) I’m not sure what that part fits but it is not for a 68-82 Corvette. Please advise me of further actions to correct this issue.
My customer number is xxxxxxxxxx
R/
David Oakey
(xxx) xxx-xxxx
"-Note: All P/S hoses exhibit different style and crimp than original."
Not sure if the term "different style" means 2" longer.
My power steering leaked and leaked until I stopped overfilling the reservoir! (It also helped to replace a cracked hose)
BEWARE there is a new company out of CA that is making new valves but they are junk. Multiple problems w/them.
Okay I'll eat my words. Patty from VDB called me back after reading this and cleared up a couple things. one they DO make their own parts and this was probably an unfortunate oversite on the QA of the parts. She is sending me another cylinder tommorow and hopefully this will resolve this issue.
Thank you Patty for your assist.
David
As I glanced through your post, looks like you started complaining within 24 hours of your frst email...
Did you think to call first?
I see you retracted some statemants, but geez, if you have the time to boot the computer up and complain, you have the time to drop a dime and see what's up.
