Alternator/voltage problem
Old Aug 27, 2005 | 03:12 PM
LARRY STREIT's Avatar
LARRY STREIT
3rd Gear
Default Alternator/voltage problem
I have a 76 and upgrade my alternator three weeks ago to a 93 amp. Two days ago my amp gage started to constantly bounce back and forth. I had both the battery and the alternator checked and both are fine but the gage still bounces contactly. Can I disconect the gage until I can find the problem and has anyone else had this problem?
Old Aug 27, 2005 | 03:54 PM
Techno's Avatar
Techno
The gauge is just for you so disconnect it if it bothers you.
You might check the wires to make sure none are loose causing the bouncing.
