Sagging doors...
Old Aug 30, 2005 | 12:46 AM
Muddywaters's Avatar
Muddywaters
Default Sagging doors...
The recent post on door alienment and shims... I can understand. What can one do about sagging doors? Drivers side is about an 1/8 low and the passenger door is about 3/16 or so low. Please advise? Don
Old Aug 30, 2005 | 01:56 AM
comp's Avatar
comp
pin's and hinge's ok ?
Old Aug 31, 2005 | 01:02 AM
Muddywaters
Comp, Pins and hinges look fine! From what I can tell anyway. I've read sometime back that the older C-3 were known for this problem and was wondering if there was fix for it... Please advise, Don
Old Aug 31, 2005 | 02:01 AM
c3 in hawaii's Avatar
c3 in hawaii
I had the same problem with my '78. what I did was take off the kick panels, put a floor jack with a 2x4 on top and placed it under the end of the door, loosened the upper door hinge and raised the door a little, then tightened the hinge. the re-adjusted the door striker and now my doors line up even.
Old Aug 31, 2005 | 11:58 AM
BLVette75's Avatar
BLVette75
My drivers side door had a similar problem. However, it also dragged slightly. Anyway, new pins and bushings fixed the problem. Have you grabbed the end of the door and tried to move it up and down to see it there is any play?
Thanks,
BLVette75
Old Aug 31, 2005 | 12:01 PM
Edzred72's Avatar
Edzred72
If you haven't removed the pins to inspect, I don't think you'll know if their OK. Bushings can be worn so I'd replace the pins & bushings FIRST (cheap) Then re-align the doors & striker. Check hinge mount bolts too by removing the kick panel (body side mount bolts) ..and door panel & upper access plate (door side hinge bolts).
Eddie
Old Sep 1, 2005 | 12:07 AM
Muddywaters
Thanks guys, yea... I feel no play by lifting the door end up and down, ummmm. but, I will remove hardware and replace bushing and pin to see what happens as I'm sure they need replacing anyway. Again... thanks!!!! Don
To Sagging doors...
