Radio removal
Old Aug 31, 2005 | 09:03 PM
Burnt71's Avatar
Burnt71
Default Radio removal
I'm removing the radio on a 79 corvette and need a special tool to unscrew the nuts on the tuning **** and the volume **** . Any body have any special tricks besides needle nose pliers ? Where can I get a tool to unscrew these nuts ?
Old Aug 31, 2005 | 09:28 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I used a thin wall deep socket when I removed mine to sent it for repair. I hope if it's the stock radio you are going to keep it.
Old Aug 31, 2005 | 10:08 PM
Burnt71's Avatar
Burnt71
Yes I'm going to keep it , but the nuts are round with two groves in them . They are not hex nuts. ?
Old Aug 31, 2005 | 10:17 PM
Glass Act's Avatar
Glass Act
Hmm... we must have different nuts Try a pair of needle nose pliers that have a 90 degree bend it may help. I can't recall seeing a special tool not to say there isn't, as I'm sure the manufacture had something special. Mine may have been replaced to a more standard radio nut during it's life..?
Old Sep 1, 2005 | 05:11 AM
rustbucket80's Avatar
rustbucket80
I used snap ring pliers. By the way the nuts are round.
To Radio removal
