Striping Removal
Old Sep 1, 2005 | 04:51 PM
aristotlewilde's Avatar
aristotlewilde
Default Striping Removal
The previous owner of my car had painted pinstriping on the car. The stripes aren't bad for now, but they had the words "It's Ruff!" painted on the back as well.
I would like to remove this if possible. Does anyone have a good suggestion for removal?
Old Sep 1, 2005 | 04:58 PM
big_G's Avatar
big_G
About 4 ounces of C-4 should do it!.....J/K
Try wet-sanding with 1500 grit wet with a soft sanding block till almost all of it is off. Then rubbing compound till the rest is off. Then polishing compound. Be careful not to sand or polish thru the paint.
Old Sep 1, 2005 | 05:16 PM
ajstr1265's Avatar
ajstr1265
Depending on your level of expertise there are a few ways to do this.
1) enamel reducer. Try a small area in a hidden spot first. ONLY DO THIS IF YOU KNOW WHAT YOU ARE DOING!!!!!
If not, I agree with wet sanding. Use 2" masking tape and put it around the letters about an 1/8" away before you sand. This will keep the paper sanding on the letters and not the paint around it and will lessen the chance of going through the topcoat of paint. You may want to only sand until the letters are transparent then compound the rest off. The condition of the paint will dictate how you do this. It is kind of a trial and error thing. Be careful not to burn through the paint
Old Sep 1, 2005 | 08:57 PM
Butch R's Avatar
Butch R
I know this is going to sound a little funny..........
easy off oven cleaner, the oven cleaner will remove the lettering or pin stripping and not touch the finish of your paint. You may see a color difference under the lettering caused by paint fading,Buffing with a little compound and than waxing will help even this out.
Good luck
B
Old Sep 1, 2005 | 09:21 PM
ajstr1265's Avatar
ajstr1265
I forgot all about this. I know a striper who does goldleaf etc. and I remember him talking about this.
Old Sep 2, 2005 | 09:43 PM
Techno's Avatar
Techno
If the car is clear coated I would either skip the sanding or be very carefull doing it. An easy test is whether your wax applicator is paint color or not.
Old Sep 3, 2005 | 09:34 AM
aristotlewilde
In the spirit of ease, I will not be attempting to sand. I will ty a spot of Easy Off, and if that does not work, I will keep it on for now.
Old Sep 3, 2005 | 08:40 PM
aristotlewilde
The easy off worked. I spread it with a sponge and used the corner of my Blockbuster card to gently scrape the lettering off. A second wipe down with Easy Off afterward and we're in business. There's a small amount of residual color, but I am sure it will be gone after tomorrow's wash...
Old Sep 3, 2005 | 09:43 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Good luck
B
What a great tip! I'm going out right now to try and remove my old, ratty stick on stripes.
To Striping Removal
