It Starts Today
Old Dec 14, 2005 | 09:25 PM
PatsLs1vette's Avatar
PatsLs1vette
Not a problem,your doing excellent work cant wait to see it finished.
kdf1986's Avatar
kdf1986
Man...I respect you guys that a) have the guts to do this and b) have the talent to make it work.
Good luck to you.....
kdf
Old Dec 14, 2005 | 09:31 PM
VETTEVIC's Avatar
VETTEVIC
Did you mean to put the trailing arm bolts in backwards? All the factory ones I have seen are installed with the nut on the outside of the frame rail as mine were. Or were yours on that way from the factory?
Old Dec 14, 2005 | 11:20 PM
collectskulls's Avatar
collectskulls
Thats the way they came off i'll look at my assmebly manual i guess thanks for the heads up
Old Dec 15, 2005 | 05:57 PM
81c3's Avatar
81c3
Originally Posted by collectskulls
bit more progress few more parts should be here early next week then i can finish putting the front end back together and go pick up my new motor and drop it on also hopefully before the new year its a rolling chassis again and i can get started on the body and interior as for the alternatior i grabbed one pat but thank you
Looks great! I'm about to lift my body off. Just have the rear hardware to take off. I'm waiting for my lift straps to arrive in the mail & I can get at it.
What did you use on the frame as far as a finish coat? Is it POR 15 or something else, & how did you do it? Spray or brush on?
Old Dec 15, 2005 | 06:18 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Looks great Skulls. You seem to be moving along at a pretty good pace
Old Dec 15, 2005 | 06:36 PM
collectskulls
I took it and and let some one else blast and powder coat it.After blasting some some peices for myself when i got the quote of $500 for the frame it was well worth it just not having to blast it.
Old Dec 16, 2005 | 03:46 PM
James1970's Avatar
James1970
CollectSkulls,
I have a serious and respectful question for you if you don't mind.
Noticing your avitar, what is the fasination regarding collecting, applying, etc. the human skull?
I don't mean any offense. Just curious and was hoping you could answer a question I've had for some time (40+years).
Thanks,
James
BTW: Beautiful Vette.
Old Dec 23, 2005 | 10:30 PM
collectskulls
doh
Old Dec 29, 2005 | 11:11 PM
collectskulls
well heres how i spent my xmas
and today i fought with the fuel and brake lines
Old Dec 29, 2005 | 11:15 PM
fl_rider's Avatar
fl_rider
Default Cool!!
I like the contrasting control arms.
Chris B
Old Dec 29, 2005 | 11:30 PM
redc3's Avatar
redc3
man your rollin'! looks great.
  #33
82MDVette's Avatar
82MDVette
Keep up the awesome work!
I am getting ready to lift the body on my 82 in 2-3 weeks. As soon as I can round up enough buddies.
Old Jan 8, 2006 | 08:58 PM
  #34
collectskulls
well motor should be here mid week and a few other parts
to finish off the chassis so figured i should start on body
guess bubba didnt want to remove the old carpet
looks like mostly surface rust here took screw driver over it coudnt poke threw but will no more when i get it cleaned off better
didnt look to close here but have fingers crossed
got most the engine bay stripped out
Old Jan 31, 2006 | 05:04 PM
  #35
collectskulls
well finally got to pick it up today
hopefully by the weekend i got the rest of it together for the most
part and can drop it and the tranny in and be done with the chassis
and concentrate on the body
sure hope i am done in time for spring
Old Feb 25, 2006 | 06:25 PM
  #36
collectskulls
well few more things done but mostly been sanding
Old May 21, 2006 | 11:51 PM
  #37
collectskulls
Default Paint
Well finally got some primer on today,thanks to the bro in law, looks like more sanding tomorrow.
To It Starts Today
Old May 22, 2006 | 12:17 AM
  #38
Scottys78's Avatar
Scottys78
Old May 22, 2006 | 01:29 AM
  #39
johnnybrewmeister's Avatar
johnnybrewmeister
any details on what your using for spraying?
no worries about using a protected booth?
Thanks for sharing the progress...this is still a "someday" project for me...when that day comes I hope I have the cajones you must have.
Old May 22, 2006 | 12:29 PM
  #40
ENFORCER1's Avatar
ENFORCER1
Looks great and your making fast progress.
You must have a good woman too, if I asked my wife to go get me some plywood and casters she would look at me like I was a martian and walk off
Keep up what your doing and thanks for the pix.
