Crazy question about rear leaf spring
Old Sep 7, 2005 | 11:33 AM
steves_77vette's Avatar
steves_77vette
Default Crazy question about rear leaf spring
I've got a pretty remote question about the rear leaf spring. I've noticed that the replacement leaf springs all have some clamps on both sides of the spring. I assume these are there to keep the leafs from rotating sideways. You can see a marked up pic here:
When I took off my old spring to recondition it, the old owner had put some exhaust clamps on the same position. THe problem is I can't find anywhere to buy these clamps as shown in the picture. Anyone have any ideas on this? Are they necessary and where can you get these buggers?
Old Sep 7, 2005 | 12:52 PM
stingray72's Avatar
stingray72
Those clamps are for shipping purposes only, and are to be removed once the spring is installed in the car.
George
Old Sep 7, 2005 | 01:56 PM
kdf1986's Avatar
kdf1986
George,
I am installing a new leaf spring in my 72. What would happen if the clamp is left on?
kdf
Old Sep 7, 2005 | 03:21 PM
Frankenvette's Avatar
Frankenvette
I just installed a replacement spring that had those clamps installed. I removed them to paint the spring and had trouble reinstalling them so I am leaving them off for now. The purpose is to keep the spring leafs from shifting since only the bottom spring is actually is kept from moving around by the spring bolts. I don't think it will hurt to not use them but you should inspect your springs everyone now and then to ensure they have not shifted and are lined up nice and neat. My previous spring did not have the clamps so the previous owner used some heavy duty plastic wire ties. I've had the car for 6 years so I can say that the wire ties lasted that long.
Old Sep 7, 2005 | 04:58 PM
Techno's Avatar
Techno
I would think if there isn't a spring shop around an RV or boat or other trailer place should carry them.
Old Sep 7, 2005 | 05:36 PM
GTR1999's Avatar
GTR1999
You can use it with or without the clamps. I usually take them off but have seen cars with them on that had many miles on them without a problem.
The bigger problem with all the aftermarket springs is they are not arched correctly and the car sits up 2" higher then stock. I think I tried all the companies and they're all the same.Then you end up using 8" bolts to bring down the body.
If you use an HD cover, the bolt pattern may be off on them. Everyone of the HD covers I used they were and you have to radius the spring for the bolts to clear. I had a brand new,clearenced spring for sale at Carlisle that 95% of the people who looked at it had no idea why it was clearenced,even when I told them.
Gary
To Crazy question about rear leaf spring
