speedometer cable replacement
Old Sep 14, 2005 | 11:13 AM
gail's red 78's Avatar
gail's red 78
5th Gear
Default speedometer cable replacement
I need to replace the speedometer cable on my 78. The one from the dash to the cruse control unit. In Chiltons manual it says you must remove the center console cluster to access the dash cluster. Is this correct? It looks like you should be able to lower the steering columm and remove the dash cluster. Anyone that has done this please let me know. Thanks
