Pretty sure I know the answer to this one. My real question now is, How dangerous do you think this is? I just noticed this today. I have checked my rag joint previously and don't remember it looking this bad. I will see if I have some old pics. For now, before I dig up all the Jim Shea articles, my questions are:
1. Is the 1968 rag joint the same as the 69 and later years or is this going to be another 68 only part?
2. Good source for the GM part?
Here are some pics. When I turn the steering wheel the pin (laveled A) actually moves. I seem to recall this is a safety feature, ie the pins keep the steering working even if the rag joint is shot. Area labeled B looks split to me. I don't recall it being that far open. The part labeled C actually slides back and forth slightly.
Here is another pic that shows the rag joint with the steering wheel turned to the right and kept under pressure: (except you would think I had the steering wheel turned to the left. I will go check again. Anyway, you can see how much flex there is in the joint)
I guess that first pic is the bottom.. maybe I just never had a good look at the bottom before??
If the pin moves side-to-side in that U-shaped cutout, then
it is loose - replace like BigG says. If it is tight, then you should
look into adjusting the column mounting at the firewall
to "center" the rag joint. There are plastic spacers used to install new ones and keep it centered as the column is mounted.
Once installed, the spacers pull right out.
I have a 68 with tele and power steering.... drum roll... do I use
GM part # # 7806391 ??????????
Don't know about the tele steering wheel. I have a standard 68 fixed steering, and a later model rag joint (flex joint) seems to fit just fine. If your a NCRS guy, you have to work a little harder to find an exact rag joint. Joints for later C3's have a stamped steel bracket surrounding diameter of the joint on both sides. Looks like it was added for extra security. When you buy a replacement rag joint, you'll probably be sent this later design if you don't check with the vendor.
MJ,
Definitely looks like a replacement steering coupler is in order!
Yes, that is the correct part number for your application. 7806391 is used up through early 1969 and has splines completely around the circumference of the coupler on the stering box side. Mid-production 1969s received a steering box with a "flat" machined into the steering box output shaft that mates to a different coupler with a corresponding flat. Chck to make certain exactly what steering box is in the car... It should be the early style, but over 37 years, original items tend to swapped out.
There is no change in application between standard, tele, and tilt/tele columns that I am aware of... The difference has to do with the mating surface on the output shaft of the steering box.
7806391 was still available from GM through the summer of last year... Which was the last time I purchased one.
Thanks Stan! You are right - My 68 was restored as a driver and lots of things have been changed. I will have to turn the wheels full right and left to see around the entire input shaft on the steering box, but if I understand what you are saying it appears to be the early style. Appears to be "full round" as Jim Shea describes it. Got the part# from his paper; now to read it carefully!
I always tried to figure out the purpose of the rag joint. Disassembly? Why no just use a U-joint? My"rag" joint from the factory has always been as hard as concrete without any flexing whatever, so something that involves flexing doesn't seem to be the answer. Maybe this is supposed to break in a head-on?
Don't know about the tele steering wheel. I have a standard 68 fixed steering, and a later model rag joint (flex joint) seems to fit just fine. .
This statement above may not be really correct. Sure my later design rag joint does fit, but I momentarily forgot that I have a 70 steering box in the car. Can't say now that the later rag joint design will fit an 68 car with the 68 column and steering box.
From what I understand, it's there as a shock absorber. Jim Shea has had some rather eye-opening things to say about using u-joints in that application.
