Serpentine conversion
Old Sep 20, 2005 | 12:14 AM
PolishMike's Avatar
PolishMike
Default Serpentine conversion
Sorry bout the stupid question but im currently dropping a zz502 into my 75. Im going with the dewitts alum radiator setup and im wondering if this kit will fit -
http://www.marchperf.com/pg72.html
Thanks again,
Mike
Old Sep 20, 2005 | 12:27 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
i am running the small block version and there is tons of room so i would have to say that the big block kit will work just fine.
Old Sep 20, 2005 | 01:02 AM
Corey_68's Avatar
Corey_68
Thanks again,
Mike
Mike I'm running thier serpentine conversion on my BB. Give them a call they have a special kit specificly for Big Block Corvettes.
Old Sep 20, 2005 | 09:05 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Are you running A/C and power steering?
Old Sep 20, 2005 | 01:14 PM
WhichVette?'s Avatar
WhichVette?
Those conversions are so nice. If only they didn't cost a kidney and your firstborn...
Old Sep 20, 2005 | 01:46 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
there's always a cheaper way to do things, unless your RICH
http://www.fidnet.com/~harleyms/serpentine%20page.htm
this is some great info for you..
Old Sep 20, 2005 | 07:15 PM
BBShark's Avatar
BBShark
That setup is too tall for the stock BB hood however I am in the middle of doing this (with the same SB truck brackets). You need to cut a notch in the cross member, make a spreader bar and do a lot of machine work to the brackets as well as machine the adapter plates. All in all probably more trouble than its worth but I love challenges.
Corey_68: Still interested in whether the March setup you used included the A/C compressor and power steering. My understanding is that the March setup would not clear with these accessories.
Old Sep 20, 2005 | 07:26 PM
Corey_68's Avatar
Corey_68
No A/c but YES to power steering. For the kit to work you have to use a remote power steering pump off of a '87 Pontiac Sunbird (found at Auto-Zone/Nappa/O'reilly's) and a remote resivoir. Later on I MAY convert to A/C and I'll just have to buy the compressor and brackets.
Old Sep 22, 2005 | 10:35 AM
Tom454's Avatar
Tom454
I was interested in this a few years ago and I contacted the March people. At that time, even after using their "kit", I would have had to get a different A/C compressor (etc) and do the P/S remote job. When you add it all up, it was way beyond reasonable. So I scrapped the idea.
The issues are compounded for an A/C & P/S car.
To Serpentine conversion
