Compression Ratio
Old Sep 21, 2005 | 09:35 AM
jaycjackson21's Avatar
jaycjackson21
Default Compression Ratio
I understand that an engine's displacement is the difference in volume between bottom- & top-dead-center, but how is compression ratio calculated? Specifically, how do vehicles with the same displacement end up with different compression ratios?
Thanks,
JCJ
Old Sep 21, 2005 | 09:44 AM
Victor's Avatar
Victor
here is a compression ratio calculator I found on the internet.
http://www.csgnetwork.com/compcalc.html
Aside from displacement, an engine's stroke, bore, and piston shape (whether it is dished or flat or whatever) all factored in.
Old Sep 21, 2005 | 09:45 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The CR is the ratio of the volume you spoke of to the volume that's left at the top above TDC (usually the vol of the head chamber + valve relief in the head).
To Compression Ratio
