Problem with T-tops!!
Old Sep 26, 2005 | 12:41 PM
samson80's Avatar
samson80
Default Wtf!!
I have a problem with my T-tops, they are caulked on the car and haven't leaked so I haven't tried to remove them yet. How and how much will it cost to fix this mess?
Old Sep 26, 2005 | 01:09 PM
samson80's Avatar
samson80
Old Sep 26, 2005 | 01:22 PM
Maymyvetteliveforevr's Avatar
Do you mean caulked (as in siliconed) to the car? If so, it depends on where it's caulked. If it's along the weatherstripping, then undo the latches and try to remove it slowly. Depending on the type and grip, it may just peel off. Worst case scenario, you may have to replace the weatherstripping. If you go to your local hardware store, they may be able to recommend some solvent to dissolve and/or help separate the caulking. They key is to go slowly. If anything, have someone pull the top up slightly to stretch the weatherstripping and take a utility knife blade to cut the silicone without touching the weatherstripping...SLOW AND EASY!!!
Old Sep 26, 2005 | 01:41 PM
fl_rider's Avatar
fl_rider
Default What he said!!
Yeah!
http://www.madvet.com/shop?frame=4.162.1301
$169.99
Old Sep 26, 2005 | 01:43 PM
KALAWAY's Avatar
KALAWAY
What does "Cocked" on the car mean?
Old Sep 26, 2005 | 01:56 PM
Scottys78's Avatar
Scottys78
Ya, I didn't get it either
Old Sep 26, 2005 | 02:36 PM
Edzred72's Avatar
Edzred72
Originally Posted by samson80
I have a problem with my T-tops, they are cocked on the car :
Cocked...calked...or cracked??
Eddie
Old Sep 26, 2005 | 03:04 PM
fl_rider's Avatar
fl_rider
Default Caulked
caulk also calk Pronunciation Key (kôk)
v. caulked, also calked caulk·ing, calk·ing caulks, calks
v. tr.
1. To make watertight or airtight by filling or sealing: caulk a pipe joint; caulked the cracks between the boards with mud.
2. Nautical. To make (a boat) watertight by packing seams with a waterproof material, such as oakum or pitch.
Old Sep 26, 2005 | 05:50 PM
Xakk's Avatar
Xakk
My first thought was as in ****-eyed, but caulked makes more sense.
Old Sep 27, 2005 | 09:22 AM
samson80's Avatar
samson80
Sorry I never was very good at spelling , the T-tops are caulked on mostly around the windshield. I don't know what type it is, but it looks pliable.
Old Sep 27, 2005 | 10:20 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I have a problem with my T-tops, they are cocked on the car and haven't leaked so I haven't tried to remove them yet. How and how much will it cost to fix this mess?
Bubba wuz there....better check the structure underneath the tops when you remove it...hope it's ok.
Old Sep 27, 2005 | 10:29 AM
samson80's Avatar
samson80
What could be some of the problems with the structure underneath the t-tops that are not obvious and if I needed them replaced how much $?
Old Sep 27, 2005 | 11:34 AM
samson80's Avatar
samson80
Old Sep 27, 2005 | 11:36 AM
samson80's Avatar
samson80
Old Sep 27, 2005 | 12:23 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
you might CAREFULLY take a razor knife and slowly cut through the caulk...
Old Sep 27, 2005 | 12:59 PM
Vette Gator's Avatar
Vette Gator
Wow! This is the most bubba fix I have ever heard of. What would possess someone to say, "them doggone T-tops is leakin' agin! The heck with bein' able to have an open car when I want it, I'll just grab this here can of spackle and seal 'em up. That oughta fix it!" Unreal.
Old Sep 27, 2005 | 01:22 PM
G dad's Avatar
G dad
Hopefully the window frame is not rusted too badly where it may have been leaking the $ estimate is prety tough until you see what is underneath all the sealant...with luck it's ok.
Old Sep 28, 2005 | 09:40 AM
samson80's Avatar
samson80
Thanks for the advise, I will just have to hope for the best when I try to remove/fix them.
To Problem with T-tops!!
