Rebuild VS Exchange
Old Sep 28, 2005 | 01:14 PM
matthud's Avatar
matthud
Default Rebuild VS Exchange
What are people's take on rebuilding wheel bearings versus exchanging them? It seems like cost wise its exactly the same. What are the pros and cons.
Old Sep 28, 2005 | 01:56 PM
72LS1Vette's Avatar
72LS1Vette
If you are talking about rear wheel bearings:
Pros:
Satisfaction of doing a tricky job yourself.
Skills learned to be able to do the job again if necessary.
Possible cost savings.
Cons:
Either have to make or buy special tools to do the job.
Special tools are expensive and can't be used for anything else.
If you don't do it right you will have to do it again or pay someone.
Buying rebuilt:
Pros:
Open the box and bolt them in.
Cons:
Maybe more expensive.
FWIW, I just bought a pair of rebuilt trailing arms with new bearings, stainless e-brake hardware and new disks from Van Steel. The arms look like new and all I have to do is bolt them on. My cruddy originals are on their way back to Van Steel as organ donors. I am doing the majority of a frame-up rebuild myself but sometimes a man's got to know his limitations.
Rick B.
Old Sep 28, 2005 | 02:25 PM
matthud's Avatar
matthud
Actually I meant having mine rebuilt by Van Steel as opposed to just exchanging them.
Old Sep 28, 2005 | 02:41 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
I'd exchange justto say I have the original parts in my car.
just my opinion.
Old Sep 28, 2005 | 03:31 PM
Tom454's Avatar
Tom454
just my opinion.
Oops... it's the opposite... if you exchange, you will not have the original parts in your car... you will have somebody elses.
Old Sep 28, 2005 | 03:39 PM
Tom454's Avatar
Tom454
Well then... it depends on the condition of yours.
For example... if yours have botched up threads here & there, and maybe the arms are banged up or man-handled... then exchange them and let somebody else on this forum eventually get yours in exchange. Maybe you won't get somebody elses man-handled arms.
I exchanged some calipers once... my originals were in great shape except for the pits in the bores which could not be honed out. I received some factory defective ones (threaded holes drilled off spec) in return.... somebody elses trash. That was the last time I "exchanged". From then on, I had my original calipers SS sleeved & returned.
Old Sep 28, 2005 | 04:39 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Time is the only pro for exchange units. The Con would be the core charge.
Old Sep 28, 2005 | 05:18 PM
danthony's Avatar
danthony
OOPS That is what I meant to say!!
Old Sep 28, 2005 | 08:53 PM
Van Steel's Avatar
Van Steel
On the forum during work hours huh. You had to think and type to fast.
Old Sep 28, 2005 | 09:02 PM
David Ey's Avatar
David Ey
I just recieved mine from vanSteel and they look GREAT. Now if I can just get them switched out and the old ones sent back so I wont be out the core charges I'll be happy. I am unable physically to do the swap and I am sure the shop I will use to change them would have charged a lot more to rebuild them than it cost for the exchange service. Did I say they really look nice?
Old Sep 29, 2005 | 05:11 PM
phclub's Avatar
phclub
New England Events Coordinator
Exchange em, Vansteel! Just had the passenger side done, no way was I gonna tackle that job.
Old Sep 29, 2005 | 05:40 PM
Hauq`'s Avatar
Hauq`
I just changed out the bearings in mine, and it wasn’t that bad of a job. I did determine to do things a little different. I strapped the control arm to a tree and then attached a chain to the axel using the break disk backwards. Then I attached my truck to the chain and pulled the axel right out. That way I didn’t need to worry about trying to pound it out. After that it was pretty much like any other pressed wheel bearing.
Old Sep 29, 2005 | 06:02 PM
big_G's Avatar
big_G
Huh?..WTF?
Old Sep 29, 2005 | 06:27 PM
David Ey's Avatar
David Ey
You happen to have any pictures?
Old Sep 29, 2005 | 06:30 PM
Techno's Avatar
Techno
Unless the place doing the rebuild or exchange has their rep to lose don't do either.
Like any of the catalog places.
Old Sep 29, 2005 | 07:44 PM
Tom454's Avatar
Tom454
You should have made a video.... it would have drawn record crowds here on the forum !
I can picture exactly what you describe... ROFL..
Old Sep 29, 2005 | 10:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
yes, we need that on video - when are you doing the other side ????
trees are also good to pull (steel) bumpers straight
should this be added to the "homemade tools" thread ????
To Rebuild VS Exchange
Old Sep 30, 2005 | 12:57 PM
Hauq`'s Avatar
Hauq`
I've got some pics at home of the set up. It worked will though, no damage to any parts.
Old Sep 30, 2005 | 01:20 PM
rihwoods's Avatar
rihwoods
I used our fire hydrant to pull my my Trooper bumper straight..wife ran and hid....
Old Oct 31, 2005 | 10:25 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Damn wish I had thought of that!
I just used a slide hammer on mine and they came right out.....
....A video of that would of been GREAT!!
