Fall/Winter Projects
Old Sep 28, 2005 | 09:49 PM
rcread's Avatar
rcread
Default Fall/Winter Projects
Now that Fall is here, it's time when many of us plan our major projects so as to not miss any prime driving weather. What fun projects do the Corvette Forum members have planned for their C3 this Fall and Winter?
I'm putting in L98 aluminum heads, a fiberglass rear spring, new shocks, offset trailing arms, Halibrand 5-spoke wheels, new carpet and door panels. I've had all the parts sitting around for quite a while waiting for the weather to turn. Next year I'm building the new small block for which I also already have parts.
Anyone else?
Old Sep 28, 2005 | 09:54 PM
kdf1986's Avatar
kdf1986
I have more projects than I have time for.
1973 new seat covers, carpet, radio bezel, KYB shocks all around, paint the rally rims silver, polish wheel trim chrome, install Camaro seat belts, rebuild carb.
1972 new seat covers, master cylinder, replace brake lines, clean engine, do a major tune up plugs, wires, points, condensor, coil, dist. cap, advance springs, set total timing to 36.
kdf
Old Sep 28, 2005 | 10:01 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Switch my 456 gears to 370 or 355 in my 79 Vette.
Old Sep 28, 2005 | 10:09 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have an Edelbrock RPM Airgap to install. Harland Sharpe Roller Rockers to install. An Al Knoch convertible top to install. Van Steele smart struts to install. I also have to fix one of the threads in my wiper door to get it to work correctly again.
Old Sep 28, 2005 | 10:22 PM
another-user's Avatar
another-user
plan on pulling the radiator and supports off and fixing or buying new supports. cleaning up the fan shroud and repainting it. rebuilding the carb. fix the rear vents. put new lights in behind the tach/speed, and finaly put the tach and speed in for the first time in 25 years.
Old Sep 28, 2005 | 10:23 PM
collectskulls's Avatar
collectskulls
ummmmmmm whats zip gets here ill be busy again
Old Sep 29, 2005 | 12:05 AM
keithkhd1's Avatar
keithkhd1
Enthusiast
First thing im doing is tapping into the braintrust of the C3 section, realizing I have the same running gear. Looks like some polyurethane bushings F&R, ball joints, shocks, a brake job, 17" wheels with 225/50 performance tires, and some tools and info to do my own alignments in my garage.
Old Sep 29, 2005 | 12:30 AM
Empatho's Avatar
Empatho
if it all goes like I plan I'm going to instal Aluminum crossmember reinforcing kit,360lb Composite spring, spreader bar, poly bushings, Smart Struts, HD side yokes, Spicer Solid HD u-joints, and try to rebuild my fisrt rear end and get 355 gears and possibly get a roll cage
Old Sep 29, 2005 | 01:08 AM
zaphodbebullbrox's Avatar
zaphodbebullbrox
i plan on driving mine, i'm taking apart my 69 truck over the winter!
Old Sep 29, 2005 | 03:51 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
It's still hitting 100 degrees out here everyday...
Plus we get to drive all winter.
But I did pick up a set of C5 seats today to put in hopefully sometime in the next couple of weeks...
Old Sep 29, 2005 | 05:30 AM
theandies's Avatar
theandies
Pulling the tranny for rebuild but I am going to do it quickly because my car is never really "down" in the winter. If it's drivable then I'm driving it.
Old Sep 29, 2005 | 07:16 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I am going to dye the interior in my 75 this fall.
Old Sep 29, 2005 | 10:04 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
We're gonna be done paint this week & going home for a good cleaning & detailing...remove wheels strip tires...polish rims & re mount rubber...not much to do at all cause I did most of it last winter
Old Sep 29, 2005 | 10:05 AM
rosslato's Avatar
rosslato
i plan on doing nothing. i'll inflate the tires, hookup battery tender, put stabilizer in the tank and put wax on the chrome parts and leave it on till the spring and thats it for this winter. last winter i tore it apart so this winter i'm working on my bike.
Old Sep 29, 2005 | 10:23 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Sell the '70 LT-1.
Sell the Subaru.
Complete garage refinishing so I have plenty of room to...
Start restoration on '71 LS-6.
Hopefully, the '71 restoration should go much more quickly than the '70 restoration did.
Regards,
Old Sep 29, 2005 | 10:26 AM
SuprJames's Avatar
SuprJames
Removing the body on my '72, blasting the frame, installing the new suspension, put LS1/T56 back in, put on some huge wheels/tire combo, drop the body back on, and put on some fender flares. I think by the time all that's done it will be Summer again.
Old Sep 29, 2005 | 10:32 AM
buffed1978's Avatar
buffed1978
Iam going to install electric cutouts on my vette this winter and count the days till spring.
To Fall/Winter Projects
Old Sep 29, 2005 | 10:33 AM
Edzred72's Avatar
Edzred72
Pull the tranny and have it rebuilt
Install new heater core
Repair busted battery box fiberglass
Install ProTopline aluminum heads, STS Sidepipe Baffles, then... post the eternal question on the Forum, "What Cam Should I Use".
Eddie
Old Sep 29, 2005 | 10:38 AM
1971Coupe's Avatar
1971Coupe
replacing all the weatherstrip on my '71
Old Sep 29, 2005 | 11:05 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
