zz502 upgrades
Old Oct 1, 2005 | 07:51 PM
tvanlant's Avatar
tvanlant
Cruising
Default zz502 upgrades advice
I have the ZZ502 crate engine in my 69. I am wondering what I can do to increase performance in it. I don't want to go as far as camshaft change, but I'm talking more like better carburetor, intake manifold, ect.
Old Oct 1, 2005 | 08:03 PM
tigers123's Avatar
tigers123
Default performance from zz502
How much do you need? 502 horsepower is not enough? Are you racing or driving on the street? I wonder if the money might be well spent on beefing up the driveline. If your car was originally a small block that is where I would put it. If it is a big block originally I would probably put it there as well, as that much hp and torque might lay waste to older ring and pinion. Have you a solid automatic or 4 speed behind that motor as well?
Old Oct 1, 2005 | 08:04 PM
84rzv500r's Avatar
84rzv500r
250 shot of Nitrous
Old Oct 1, 2005 | 08:14 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Nitrous! and pipes
Old Oct 1, 2005 | 08:15 PM
tvanlant's Avatar
tvanlant
Cruising
Good trans and rear. I was just wondering if there was anything out there to make a couple more quick easy horsepower. If not, Ok.
Old Oct 1, 2005 | 08:16 PM
tvanlant's Avatar
tvanlant
Cruising
I do have a nitrous works kit. How big of a shot do you think is safe on this engine?
Old Oct 1, 2005 | 08:39 PM
84rzv500r's Avatar
84rzv500r
It comes with forged Crank, Rods, and Pistons so the bottom end should be good for 800+ YMMV
I'm thinking about a plate behind the throttle body on my Ramjet. You can never have to much Horsepower and Torque
Old Oct 1, 2005 | 08:55 PM
Corey_68's Avatar
Corey_68
On the street w/ street tires you'll be fine. Once you add slicks into the mix that "Good Trans and Rear" will be no more.
That engine can take a 200hp shot without batting an eye.
Old Oct 1, 2005 | 10:01 PM
hezekiahmunson's Avatar
hezekiahmunson
What carb/intake/exhaust do you have now? Have you had it dynoed?
Old Oct 1, 2005 | 10:03 PM
Alexarz's Avatar
Alexarz
How about a good exhaust such as Hooker Headers w/ spiral turbo baffles. I would also upgrade the ignition to an MSD 6AL & MSD distributor, if you have not done so already. If you want to go deeper at a later time, I would replace the heads with AFR, Dart or Pro Topline aluminum heads along with a better cam and intake.
Old Oct 1, 2005 | 10:49 PM
68 Yellow 468's Avatar
68 Yellow 468
You have some good suggestions here to consider.
We have ZZ502 in our 69 Camaro and just got through with a few upgrades to it:
1). Beehive valve springs and roller rockers.
2). Pretty good sized hydraulic roller cam.
3). MSD 6AL, MSD coil, and MSD non HEI dist.
4). We also pulled the heads, checked compression (was actually 9.8 instead of the 9.6 advertised) and upped it a tad.
If I had ONE item I would recommend as an easy upgrade it would be the beehive springs and the roller rockers. You will definitely pick up good power, but more importantly you will pick up RPM. The 502 has a factory 'redline' of 5,800 and this is where the valves would start to float. We can now run up to 6,500 and the car pulls strong all the way there.
Giving yourself an extra 700 RPM's up top would make your ride that much more of a monster on the big end.
Enjoy it.
Bryan
Old Oct 1, 2005 | 11:00 PM
GDaina's Avatar
GDaina
Solid roller will wake the 502 up....aks me how I know.... You will be amazed at the difference between hydraulic and solid.
Old Oct 1, 2005 | 11:32 PM
duliz's Avatar
duliz
What about the Edelbrock Multiport fuel injection kit. It's suppose to add about 20 to 30 horsepower, What about roller rockers??? ZZ502 with Performer RPM pro-flo
Old Oct 1, 2005 | 11:48 PM
GDaina's Avatar
GDaina
Don't forget, the 502 horses are at the flywheel, deduct 15-20% loss from the flywheel to the wheels.
Old Oct 2, 2005 | 02:56 AM
BB wowbagger's Avatar
BB wowbagger
Supercharge it..
Old Oct 2, 2005 | 03:02 AM
WhichVette?'s Avatar
WhichVette?
Tuning. Make sure you're getting every one of those horses...
Old Oct 4, 2005 | 08:11 PM
Glensgages's Avatar
Glensgages
Enjoy it.
Bryan
..... "SUPPOSE", just "SUPPOSE", a guy wanted to bracket-race a fairly-stock ZZ502, in a low 12-second car, without swapping the cam/lifters/headers.....
would the valve springs and roller-rockers produce that much more RPM, and reliability, with the OEM cam?
I'm not doubtin' ya, just asking, as I've seen them run, but not known what's been done to them.
To zz502 upgrades
Old Oct 4, 2005 | 09:24 PM
Alexarz's Avatar
Alexarz
I would estimate that those extra revs will produce at least lengthen the powerband enough to make a significant difference. It all adds up. Think of it this way; pretend you are in 2nd gear. At your new shift point you will be going faster, which translates into being higher in the rpm's when you shift into 3rd. When you shift into 3rd your car will be in an rpm range where it is putting out much more hp because it will be revving higher at this point.
Old Oct 4, 2005 | 09:26 PM
68 Yellow 468
I would tend to agree.
Also, an additional 700 rpm blows up your 'area under the curve'.
Bryan
Old Oct 4, 2005 | 09:47 PM
Glensgages's Avatar
Glensgages
Alexarz & 300ZXTwinTurbo:
thanks for your insight!
I'm not-really concerned with the extra HP/TQ the valve-springs/rockers may produce (although they'd be nice ):
when the original 440HP/502CID was introduced in the mid/late '90s, I recall a few bracket-racers claiming that the hydraulic lifters and/or valve-springs often failed after a 100 passes, and they lost several hundred RPM as a result.
I ain't worried about Low ET, just a reliable, consistent, zero-maintenance low-RPM stump-puller that'll last several hundred, if-not several thousand, runs with a 5500 RPM shift/trap speeds.
Glen.
