New headers work with original pipes?
Old Oct 3, 2005 | 09:46 PM
mlub's Avatar
mlub
Default New headers work with original pipes?
I think I may have a leak in my exhaust manifold. Will any modern headers fit in with the stock '69 pipes? Maybe there are plenty, I just dont know.
thanks,
michael
Old Oct 3, 2005 | 09:59 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Any muffler shop should be able to weld an adapter on your existing pipes to adapt/bolt to headers.
I think the "shorty" headers are a true bolt on - other members may know
Old Oct 3, 2005 | 10:10 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I run long Hooker Headers, but my exhaust pipes were added after the headers were put in. But you can use long or short and have a adapter welded to the existing pipes, as long as your pipes are in good shape. Is your manifold leak just a gasket..?
Old Oct 4, 2005 | 12:49 AM
mlub's Avatar
mlub
thanks for the info guys
havent had time to check it out yet...itd be nice if it was just the gasket
To New headers work with original pipes?
