The small-block Chevy 350 is the most upgradeable and easily modified engine out there. Don't worry about stock performance...this is the place to come learn about how you can put some fire in that engine.
Have an knowledgeable person look at the car. You should be more worried about rust in certain key areas than the stock engine performance. It's easy to upgrade the engine, hard to fix rust...
This is the best advice here. The drivetrain is upgradable.
A rusted frame or birdcage (body frame) is not.
Sounds like a fair price for a running 76.
I think the L48 is a good reliable Chevy engine.It can be tweaked to run faster pretty easily.I think sometimes people get to caught up in the L48-L82 thing.There`s so many other things to consider when buying a Vette of this vintage.
Get some loud mufflers and drive it around like you have 500 hp under the hood. When that little Honda wants to race at the light, let him go, and just ease off. He can't say he beat you cause you didn't race him. The fool just took off in his Honda!
My 76 was stock when I got it. Top rebuild with upgraded carb, cam, intake manifold, and big valves. She will fly now when you hit the gas! The L48 is very easy to work on. I just can't do body work, so follow the advice here about checking it out for rust.
When it redlines in 4th, do you have the feeling there should be another gear??
I grew up driving stick shifts in Europe and I still believe that 'real men drive manuals'. That said, there are times when I'm moving up through the gears and I do try to slip her into 5th.
Hey Guys, New to the forum here. About 2 weeks ago I picked up a 75 vette with a 4 spd. manual. The car came with a complete new Al Knoch interior and only has 37k original miles. I was reading online and saw that there were only a little over 1000 manuals made out of 34 thousand units. Is this true? The car is all matching #'s and the best part is that it was only $1500.
Can anyone give me a few good ideas as to what to bolt on under the hood? I want to keep the original engine but want to get some more HP. I figure carb, intake cam etc. Any pointers? Any feedback would be greatly appreciated. Thanks!
There were 10,000 '75s built with manual transmission, not 1,000. Do a search for engine upgrades (like you've already done to dig up this thread) and read, read, read. Carb will get you nothing, cam and heads is where the ponies are at.
There were two 4 speed manuals available in 1975. 1,057 cars had the optional closre ratio 4 speed. The majority of manual cars (8,935 cars) had the standard wide ratio 4 speed. Notice the site only list the optional engine, not the base L-48.
The 4 speed just strikes me as strange. At what speed does it redline in 4th gear? When it redlines in 4th, do you have the feeling there should be another gear??
In 1976, the 180 hp L48 with a 4 speed had 3.08 or 3.36 axle ratios available. I don't think there is enough hp to redline the engine in 4th gear with either ratio. Somebody will correct me if I am wrong. I am sure I can do it with my car (over 400 hp) and 3.36 gears, but I would probably be doing around 135 mph at 5600 rpm. I don't have the stones to drive my 41 year old car that fast, let alone shift into overdrive and go for more.
Bought my '76 4sp. / 3:36 gears , for $8500 w/ 45k miles...... then spent almost another 1k to ship from Pennsylvannia to my doorstep in S. Texas.
180hp is not going to set any acceleration records ...but as others advise ..350sbc upgrades are easily done with a little $$$$
(cheapest way would be drop in a set of 5:88 cogs ) but you would be in 4th at the end of the block ..LOL
and yea I like the cool factor you get when "puttin' thru town
