Quick cooling system question....
Old Oct 12, 2005 | 10:58 AM
ShaneLU97's Avatar
ShaneLU97
Default Quick cooling system question....
Sorry for the BASIC quetion but I could not find the answer in the Hayes Manual or Car Manual last night (unless, like a bonehead, I missed it). What is the approximate amount mixture (i.e. coolant plus water) I will need to flush the cooling system on my 73 w/ 350sb?
Need to buy some at lunch and we are doing a coolant flush tonight at class.
Shane
Old Oct 12, 2005 | 11:09 AM
Z-man's Avatar
Z-man
Won't you be using a special flush mixture made especially for this? It would have the mixture right on the can. Coolant is getting more expensive. I can't imagine why you would buy a couple of gallons just to flush it and toss it away. Also, unless your car is really, really dirty, you could just flush with a constant stream of fresh water. This would remove any loose deposits. Suspended particles and chemicals should come out with your previous coolant. Just my .02...
Old Oct 12, 2005 | 11:44 AM
ShaneLU97's Avatar
ShaneLU97
Sorry, I mistated what I am doing....Not a full flush, etc, more of a drain old/refill with new so changing the coolant. So I am trying to figure out what the approximate refill capacity is.
Shane
Old Oct 12, 2005 | 02:11 PM
Z-man's Avatar
Z-man
Ahhhh....
I just refilled my system from empty, however, I have an aftermarket radiator which is slightly larger. It seemed to be about 4 gallons.
I'd bring 2 gallons of antifreeze, and two gallons of distilled water. Add one gallon of each, then add 1/2 gallon of each, then 1/4 of each, etc., until it's full. That way you get closer to a 50/50 mix. It's better from a freeze standpoint to have somewhat more coolant than water.
Good luck -
To Quick cooling system question....
