computer prom
Old Oct 21, 2005 | 07:10 PM
jimbow's Avatar
jimbow
Default computer prom
After swapping out my TH350 automatic tran.out of my '81, for a 4 speed Muncie, I find out to get optimum gas milage, I'll need to swap my "automatic" computer for a computer out of a 1981 with a manual tranny. Actually, the "PROM" (computer chip) is all I actually need to switch.
Swell...I haven't been able to find one, either the entire computer w/Prom, or just the PROM.
I thought I would go the Hypertech route, but that requires using 93 octane & I don't need the extra expense.
Does anyone MAKE these chips? I know GM doesn't ., nor do they have any.
Or, where would you suggest looking for one...other than breaking and entering....I've tried most of the salvage yards. thanks again, jim
Old Oct 21, 2005 | 09:27 PM
Older Than Dirt's Avatar
Older Than Dirt
Jim, if my computer was for a 4-speed I would just give it to you. That part will be hard to find. Try calling Gary Gruhala 636-586-3909. I bought my clutch pedal assembly and a few other things from him. He doesn't overcharge and he's great to deal with. If he can't help you he might be able to steer you in the direction to someone who can. Good luck!
Old Oct 21, 2005 | 09:50 PM
jimbow's Avatar
jimbow
Older than dirt, thanks ...for the tip and the good words. Jim
Old Oct 22, 2005 | 12:02 AM
Mr.L's Avatar
Mr.L
I would double check that. As far as I know th350 have no wires running to the computer. The computer just controls the carb air fuel and other emission stuff. You can get a custom chip they run $100 to $150. You are very limited as to the things you can do with computer controlled carbs as far as the computer goes. I have an 81 with the factory setup like yours, mine is auto. Around town It is a killer on gas 10 to 12 MPG, on the HWY I get 29MPG. If you really want to get better gas mileage save up and convert to TPI. That is the way I'm going.
Old Oct 22, 2005 | 12:17 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The computer does control the lock up for the torque converter. Also, since it is a different part number, I imagine that at least the curve is different if for no other reason that different number of gears.
Old Oct 24, 2005 | 03:49 AM
stickboy's Avatar
stickboy
Hypertech sells a 4spd chip. I think the ECM is the same between 4spd and auto
Old Oct 24, 2005 | 06:18 AM
Twin_Turbo's Avatar
Twin_Turbo
the ECM takes a reading off the VSS, it's behind the cluster, a blue or yellow box w/ an optical emitter/sensor in the back of the speedo. Also the ECM controls the metering rods depending on load and the ignition advance/knock retard. There is a difference between the auto and manual..however I would just pull all that stuff off get some nice performance parts on there and truely enjoy the manual.
To computer prom
