New engine stand and tranny
Old Oct 24, 2005 | 11:00 PM
PolishMike's Avatar
PolishMike
Default New engine stand and tranny
Got the tko-600 on there. Should there be a boot where the clutch fork is? I didnt get one with the kit
Welded up a motor stand to support the engine by the mounts. also supports the tranny. A little surface rust on the square tubing, nothing serious, only using this stand for maybe a month more than its either powdercoating or garbage. If i end up keeping it then wheels will be installed.
Old Oct 24, 2005 | 11:12 PM
GDaina's Avatar
GDaina
First Class work...
Old Oct 25, 2005 | 09:50 AM
CGGorman's Avatar
CGGorman
Looks like a Keisler kit? Hope you like it! I LOVE mine. Which OD ratio did you get? If it's the .64 make sure your rear gearing is no lower (nemerically) than 3.36:1. I've got 3.36's and my cruise rpm at 65 is only 1700. I'm thinking of bumping up to 3.73s... My current engine lugs along fine at that speed, but the new one will be cammed much higher and I don't think a cruise speed less than 2000 will cut it.
Yes, there should be a boot on the fork. Doesn't surprise me that it wasn't included... You should be able to find one most anywhere that sells Chevy parts. That bellhousing and fork was used for decades...
Old Oct 25, 2005 | 10:20 AM
PolishMike's Avatar
PolishMike
My rear is 3.08 i think. I got the .64 also, but i think being EFI i can keep it running good just above 1000, if not then ill cruise on 4th. This is not going to be a daily driver.
Old Nov 3, 2005 | 01:15 PM
comp's Avatar
comp
need to add these to Home made tool thread
Old Nov 3, 2005 | 02:02 PM
norvalwilhelm's Avatar
norvalwilhelm
I'm running 308 gearing also with the tremec and at 1200 rpm I am running 50 mph and 1550 at 60. The motor seems quit happy running along at this rpm.
Old Nov 3, 2005 | 07:29 PM
PolishMike's Avatar
PolishMike
It works, and technically i made it in my dad's metal shop so its not "home made" lol.
Glad to hear that. I wasnt really expecting any drivability problems, but its always good to know.
Old Nov 3, 2005 | 07:34 PM
matchframe's Avatar
matchframe
Very Cool!!
www.bigdogvettes.com
Old Nov 3, 2005 | 11:23 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Old Nov 4, 2005 | 12:07 AM
74droptop's Avatar
74droptop
Norval, what model tremec do you have?
How has it been holding up behind that blower motor?
Old Nov 4, 2005 | 01:00 AM
PolishMike's Avatar
PolishMike
i cant get enough of this engine so i might as well through a couple new pics up
Old Nov 4, 2005 | 01:01 AM
PolishMike's Avatar
PolishMike
hmm now how the hell am i going to put it in the car???
To New engine stand and tranny
