Heads
Old Oct 25, 2005 | 01:11 PM
whitesnake81's Avatar
whitesnake81
Default Heads
Which would you use on a 383 stroker engine aluminum or iron Vortec Or dart Heads? What cam for low end power?
THANKS!
Old Oct 25, 2005 | 02:24 PM
redc3's Avatar
redc3
i used motown ( world products ) -2 heads, 2.08/1.90 valves, 64 cc, iron heads. they flow way more than the vortecs. maybe not as much as the afr's, which i might upgrade to eventually. the -2 heads cost around 1300 at local speed store. but i couldnt be happier with the world heads.with so many to chose from in the aftermarket. youll have to do your home work.aluminum will only save weight. no good or bad comparing aluminum to iron.
Old Oct 26, 2005 | 09:52 AM
whitesnake81
Thanks!!
To Heads
