What mechanical fuel pump?
Old Oct 27, 2005 | 01:24 PM
ImBatman's Avatar
ImBatman
Default What mechanical fuel pump?
What do you guys recommend for a fuel pump?
GPH rating?
return line?
I want something chrome but want to make sure I get a quality one. I read a link a while back about someone using the Edelbrock and having inconsistent fuel pressure.
Old Oct 27, 2005 | 04:34 PM
JohnS_77's Avatar
JohnS_77
I posted a similar question back in the summer. Since I'm running mostly stock, I was advised to go to Napa and get a replacement from them. It bolted right in.
Old Oct 27, 2005 | 05:42 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Someone here said that the stock pumps are good to over 400hp, and that the 3/8" fuel line is good to over 500hp, so i would go and pick up the standard pump...prob around $20 if I remember correctly.
trw
Old Oct 27, 2005 | 06:07 PM
comp's Avatar
comp
a good stock replacement
Old Oct 27, 2005 | 06:23 PM
GDaina's Avatar
GDaina
Nothing wrong with a stock AC pump...don't forget the high H.P. BB's, L-88's, ZL-1's used the stock mechanical pump...BB's don't have a return line.
Before the 533 cube, I ran the solid roller in the 427 and stock pump..worked like a charm.
Old Oct 27, 2005 | 06:44 PM
b71vette's Avatar
b71vette
Default It was me that had the Edlebrock with
inconsistent fuel pressure. I went with the Carter Pump, natural aluminum finish. Part#M60969 was the Carter I used, this is the Nascar pump 150+ GPH with the AN fittings, you may not need that though.
Old Oct 27, 2005 | 07:36 PM
groovyjay's Avatar
groovyjay
If you insist on using mech. pump take a look at this:
http://www.racepumps.com/features.html
Old Oct 29, 2005 | 07:05 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
one of the guys is using that on his turbo engine with good results.
Old Oct 29, 2005 | 07:20 AM
Steve's74's Avatar
Steve's74
Hhmm.... My nearly stock '74 LS-4 has a return line. And I know it's factory. Used a stock replacement CarQuest unit on it. Of course, it hasn't moved off of its jack stands yet....
Steve
Old Oct 29, 2005 | 07:33 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Carter BB:
To What mechanical fuel pump?
