First Winter With Vette
Old Oct 29, 2005 | 08:42 AM
drswitala's Avatar
drswitala
Default First Winter With Vette
This will be my first winter with my 80 L-48. I would like to keep driving it right up until the first snow of the season. Should I be concerned with the cold weather causing cracks in the body. It can get pretty cold in this part of the country.
Old Oct 29, 2005 | 08:47 AM
PhotoVette1's Avatar
PhotoVette1
This is a production automobile. As such, it was made to be driven in all weather conditions. I drove my '81 'Vette (it was 1 year old at the time) all year in CT for 3 years with no ill effects.
(Then I moved back to Miami and it got stolen...)
I use my '77 all year round. There's one little crack on the hood--I think from when a model laid on it however.
Old Oct 29, 2005 | 10:16 AM
BUGGSY1970's Avatar
BUGGSY1970
Cold weather should not cause fiberglass to crack. I wouldn't worry. I drive mine here in NY until the first snow and it gets pretty cold here also. I have a few cracks in the paint but that is not caused by the cold.
Old Oct 29, 2005 | 10:57 PM
Hwy St*r's Avatar
Hwy St*r
I drive my '78 all year round in NJ. The body does make some noise on really cold days when I back it out of the driveway but that's all. Also contrary to the myth these cars are not too bad in the snow either. I've got caught a time or two. The weight distribution helps but you have to watch the clearance. I mostly worry about the other drivers and for that reason I prefer to park it when I can in bad weather.
-Pete. KEEP DRIVING!!!
Old Oct 29, 2005 | 11:32 PM
mandm1200's Avatar
mandm1200
I think it would have sounded better if you said " I think from when I laid a model on it."
Old Oct 30, 2005 | 01:28 AM
PhotoVette1
I got to tell the truth though.
I am engaged to her now however~gods!~ I'm marrying my second 19 year old--at my age too. Oh well, we guys take what we can get.
Old Oct 30, 2005 | 01:29 AM
00fxd's Avatar
00fxd
Many years ago I drove my '74 through many winters. They are very good in the snow. How cold is pretty cold? Where I lived it could get very cold. I got into my one very cold day and the windsheild cracked. All the way across.
Old Oct 30, 2005 | 04:20 AM
grybdn's Avatar
grybdn
as long as the ground is dry, roads are clear you'll see me and my C3 cruising around...
Old Nov 5, 2005 | 07:54 AM
drswitala's Avatar
drswitala
Thanks for everyones input. The weather here has actually been pretty warm so far this fall which makes for nice driving through the areas parks and taking in the fall colors. as someone said as long as the roads are dry (and salt free) I will be cruising.
Old Nov 5, 2005 | 08:41 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I put mine away last Friday. It is not the cold that concerns me, but the salt dust on the road.
Oh well, she sleeps until April 1...
Old Nov 5, 2005 | 08:50 AM
drswitala's Avatar
drswitala
I share your cocern about the salt dust. Around here if it snows one inch they put down two inches of salt. The roads will have to be CLEAN for me to take the car out in the winter.
Old Nov 5, 2005 | 10:33 AM
El_Cid's Avatar
El_Cid
,but you're giving Michigan to much credit, its more "if there's a possibility of snow, 6-7 inches of salt will be laid overnight, just in case, and another 2-3 in the morning, just for good measure"
To First Winter With Vette
