Big block question..
Old Oct 29, 2005 | 10:36 AM
rihwoods's Avatar
rihwoods
Default Big block question..
Just replaced power steering bracket on 69..it broke when bolt vibrated out...but noticed slight mis-alignment of alternator belt to power steering pulley....is there a pulley kit for these alternators for BB application to get better alignment? (Delco Remy 12si,I think)...here is pic....
Brackets all good and fit right....but looks like alt pulley needs washer or shim to move it forward a bit....???
Also, I put locktite on all bolts to pwr steering/alternator brackets..
Old Oct 29, 2005 | 10:53 AM
brianlewis60's Avatar
brianlewis60
Default hope this helps
I hope that you can try this to see if it helps you out
Old Oct 29, 2005 | 11:40 AM
rihwoods's Avatar
rihwoods
Thanks..that is easy...I'll get back to you later on how it worked out...
Rich
Old Oct 29, 2005 | 08:58 PM
CGGorman's Avatar
CGGorman
I used washers on the shaft, but same principle. Interesting that this is a widespread problem...
Old Oct 29, 2005 | 09:22 PM
72ls5fla's Avatar
72ls5fla
Hi ...
The pulley on the alternator is incorrect for PS setup.
The factory pulley has an additional 3/8" before the groove.
You can shim it with washers (bubba style) or get the correct pulley. I'm sure that they are available from Paragon, CC or Doc Rebuild.
Bill
Old Oct 29, 2005 | 09:33 PM
lvjohn's Avatar
lvjohn
I have a 71 BB ,had to buy different pulley for the alternator
got it from. www.paragon.com
Old Oct 29, 2005 | 09:34 PM
lvjohn's Avatar
lvjohn
Wrong link sorry try this one. http://corvette-paragon.com/images/h...aragonHome.gif
Old Oct 29, 2005 | 10:33 PM
rihwoods's Avatar
rihwoods
Originally Posted by 72ls5fla
Hi ...
Bill
That was my thought....(like to went nuts finding a reference to this issue)...I'll go after the correct pulley...thanks for the info and to the guys who suggested washers...
Old Oct 30, 2005 | 12:04 AM
Les's Avatar
Les
I just had this problem fixed- went to the shop that built my alternator & the guy came out to see my car when he heard the solid lifters. We talked cars for a few minutes & he reshimmed the pulley at no charge.
Old Oct 30, 2005 | 12:18 AM
rihwoods's Avatar
rihwoods
Better pic of mine....P/S pulley is hard to see,but belt angle off.....
I might need this...
http://www.corvette-paragon.com/cata...9D1214&picID=1
Old Nov 8, 2005 | 08:41 AM
rihwoods's Avatar
rihwoods
Hi ...
Bill
Installed correct pulley....belt lines up good....but...look at tip of fan blade....it touched power steering pump shaft....just barely....
(The upper pic is with new pulley.)...took a cutting wheel,and flushed pump shaft with nut...tip of fan blade clears by 1/4" now...
To Big block question..
