how to attach stingray emblem?
Old Oct 31, 2005 | 12:54 AM
driver68's Avatar
driver68
Default how to attach stingray emblem?
almost set to buy my first vette ('72 coupe). It is missing the Stingray emblems on the front fenders. Holes were filled on last paint job. I really like the emblems, and want to add them back. What is the recommendation? drill holes for the studs or grind off the studs and use some sort of adhesive? Does anyone have the exact measurements of where these emblems should be?
I really appreciate this forum and all the help and advice I have received even BEFORE owning my first vette!!
Old Oct 31, 2005 | 12:57 AM
strokervette's Avatar
strokervette
I would try to locate the original holes from the inside and drill out.
Old Oct 31, 2005 | 10:29 AM
Buzzardz_vette's Avatar
Buzzardz_vette
The new emblems I bought had adhesive and prongs for the holes, just peel and stick. You can just cut the prongs if you don't want to drill holes in your fender. Of course you'll need to figure out the alignment.
Old Oct 31, 2005 | 10:30 AM
own2vettes's Avatar
own2vettes
Yikes!!! I think I would go the route of grinding down the studs and then stciking it to the car with some type of trim adhesive. I can picture a big chip of paint flying off the car (think exit hole from a bullet). But if you are handy and know what you are doing, go for it!
Old Oct 31, 2005 | 11:30 AM
Paul L's Avatar
Paul L
Double-sided 3M trim tape will do the trick.
Old Oct 31, 2005 | 06:13 PM
copter's Avatar
copter
Yes the emblems come with two sided tape allready on them.Just snip off the prongs and file down what you can't get to with the snips.Be careful you don't file into the tape.Real easy.If I can do it a blind moron can.
To how to attach stingray emblem?
