I come asking for help and advice once again.
I am going to look at a 72 convertible auto with ac please help me with a detailed list of things I should look for and things I should lookout for.
As you can tell I am new to the corvette world so be patient please I am learning fast from reading ALL I can on this site it’s great!
Thank you in advance
if you search on buying advice you will get alot. but the major things are frame and brid cage rust, the body condition (paint, fiberglass), if you are buying it as a NCRS oringial style car, or a driver, or a project car.
From: The reason time exists is so everything doesn't happen at once
Check the frame and around the windshield for rust. Get the car up on a lift and check for leaks. If you don't know much about these cars find someone in your area (a CF member or a member of a local Corvette club) to look at the car with you.
