old Holley - rebuild ?
Old Oct 31, 2005 | 10:26 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default old Holley - rebuild ?
It's a 750 Holley DP so I was told .... I was also told this carb is antique
It came with the Vette when I bought it, never got it to run right and the gas milage was horrible... it smelled pretty bad from the tailpipes (gas) so I assume there's something wrong with this carb... I replaced it with a 600cfm Edelbrock, now it's running fine.
The white wire (second photo) was added by the previous owner - looks nice
Is it worth rebuilding ? What should I do - put it in a box and send it to Lars ??? I'm not a carb expert (engine AND food)
Old Oct 31, 2005 | 10:57 PM
evil herbavore's Avatar
evil herbavore
That is NOT a dbl pumper.
It's a holley 4011 model vacuum secondaries.
The 4010 and 4011 were considered "failures" because they never caught on, but they had many good features;
-far less gaskets below fuel level and cleaner jet changes
-annular boosters
-dual power valves
That white wire appears to be holding the choke open.
Old Oct 31, 2005 | 11:11 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would just put it in a box period
Old Oct 31, 2005 | 11:14 PM
Jclgodale3's Avatar
Jclgodale3
yep...just put it in a box and send it to Alabama Nice paperweight
Old Oct 31, 2005 | 11:24 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
it is in a box since I removed it
Old Oct 31, 2005 | 11:58 PM
Jclgodale3's Avatar
Jclgodale3
ok...step one completed...now just throw it towards N Alabama
Old Nov 7, 2005 | 02:58 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Heres an exploded veiw
http://www.holley.com/data/TechServi...ded%20View.pdf
I could probally rebuild it but it whouldnt have a 1-2 day turn around like a normal holley But since you have another carb on it now it whouldnt matter than much.
Old Nov 7, 2005 | 04:24 PM
694speed350's Avatar
694speed350
Default holley carb
is this one of the spreadbore holleys? if it is i might be interested in it.
Old Nov 7, 2005 | 06:45 PM
GDaina's Avatar
GDaina
nothing to it rebuilding a Holley...if you know hot to use a screwdriver, you can rebuild the Holley.
Old Nov 7, 2005 | 09:55 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I'll email you once I get home, need your adress to ship it. Time doesn't matter, I'd like to have it available next year when I have my stroker built ... the 600cfm that I have on the 350 is too small for a 383 ?? I guess once I have the stroker running I'll find out which carb is better
Old Nov 7, 2005 | 10:25 PM
BigBlockk's Avatar
BigBlockk
Now, am I seeing this wrong or does that thing have a vacuum secondary diaphragm AND dual accelerator pumps?
BigBlockk
Later.....
Old Nov 7, 2005 | 11:55 PM
GDaina's Avatar
GDaina
BigBlockk
Later.....
You're seeing things...
Old Nov 8, 2005 | 05:16 AM
breathial's Avatar
breathial
The 4010/4011 carbs (square bore/spread bore flanges) were introduced in the late 80's. While they run pretty good out of the box, they never really caught on, because there aren't many modifications that can be done to them, hence, they weren't popular with the "speed" crowd...
But for a cruiser? Yeah, the work pretty well. I had one on a healthy 396 BBC, and it worked very nicely.
To old Holley - rebuild ?
