Problem Using Cherry Picker
Old Nov 4, 2005 | 06:37 PM
79vetter's Avatar
79vetter
Default Problem Using Cherry Picker
My stock L82 Intake manifold had the 2 brackets mounted on it that would allow you to attach the hook and chain to the cherry picker.
I have switched to a Professional Products Intake and now my 2 bolt bracket that I pulled off that manifold will not line up on any two holes side by side on the new Intake manifold for me to be able to have a place to "grab" .
What is a guy to do about this??
Old Nov 4, 2005 | 06:42 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
A piece of steel & a torch. Fab your own.
Old Nov 4, 2005 | 06:56 PM
Z-man's Avatar
Z-man
Just get some grade 8 bolts with washers and run them into the heads through the ends of the chains.
Old Nov 4, 2005 | 09:27 PM
Russ Bellinis's Avatar
Russ Bellinis
If you can't get to the back of the head because of firewall clearance, you can do the same thing with a couple of long grade 8 bolts through the intake manifold into the cylinder head.
To Problem Using Cherry Picker
