Tips for engine building
Old Nov 10, 2005 | 10:08 PM
Maine Vette's Avatar
Maine Vette
Default Tips for engine building
I thought this could be an interesting and educating topic. What is the best tip or hint you would give to someone building an engine?
Old Nov 10, 2005 | 10:10 PM
Maine Vette
Must be getting late... This should have gone in the tech section. My apologies.
Old Nov 10, 2005 | 10:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Read alot of books , take your time and buy some mics, calipers bore gauge etc.
Old Nov 10, 2005 | 11:33 PM
Civis's Avatar
Civis
Get a cheap old 2-bolt, cast-everything small block chevy and rebuild it (then sell it), so that you get a feel for things before you start building a hefty, 4-bolt, forged-everything performance motor. I did that way back in the old days with a Ford 302W and it taught me a lot.
Old Nov 11, 2005 | 10:28 AM
79vetter's Avatar
79vetter
I just rebuilt mine for the first time and am planning on starting for the first time tonite. You will find that the machine shop will take care of some of the particulars . I bought a book called :How to rebuild the Small Block Chevrolet. It had pictures and detailed the process. I certainly learned a lot from this experience even though time will tell if I got it right. A crate engine is going to be cheaper and faster once you add up all the little and big expenses however I wanted the learning experience personally. I found that there is nothing that is really hard about the process- meaning I didn't get too stumped on any part of the process for very long. Take your time- do things right- you will have a million questions- which is Ok.
Old Nov 12, 2005 | 09:31 PM
comp's Avatar
comp
when you measure things write it down don't try to remember
Old Nov 12, 2005 | 09:39 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Nov 12, 2005 | 09:44 PM
Pete K's Avatar
Pete K
No such thing as "too clean"!
Old Nov 12, 2005 | 09:48 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Nov 13, 2005 | 02:08 AM
comp's Avatar
comp
To Tips for engine building
