1/2" wheel studs
Old Nov 15, 2005 | 04:21 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default 1/2" wheel studs
I'm trying to find the "correct" ARP 1/2"x20 wheel studs for the rear axle. those of you who have done this conversion; what knurl diameter did you buy ? I think the smallest is .520" or so... is there enough meat in the spindle to drill that big ??
Old Nov 15, 2005 | 08:22 PM
comp's Avatar
comp
Old Nov 16, 2005 | 06:23 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
nobody knows ???
Old Nov 16, 2005 | 06:39 PM
Twin_Turbo's Avatar
Twin_Turbo
I have moroso studs and have a very nifty drill fixture and a ground down drill for the correct knurl diamter (slightly undersize) I got it from Norval The knurl was something in the .52 range also if I remember correctly, there's plenty of meat to drill them that big.
Old Nov 16, 2005 | 06:54 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks, I guess I'll place my order tomorrow. I feel a little "warmer and fuzzier" with 1/2" back there. On the front axle I have the ARP studs in M12 which is about .040" larger than 7/16" but for the rear I guess bigger is better (especially with spacers/adapters)
To 1/2" wheel studs
