Battery Cut Off Switch
Old Nov 16, 2005 | 08:55 AM
lvrpool32's Avatar
lvrpool32
Default Battery Cut Off Switch
anyone using one? I am trying to find a good place for one (as part of my Heinz Johnson #4 L88 race car theme....)
Dont really want to cut a hole in the body.....maybe on my AIR wiper cover...hmmmmm.
Old Nov 16, 2005 | 08:58 AM
Blue 74's Avatar
Blue 74
I have one at the battery. Car came with it. Have seen them in catalogs for around $11. Just bought another one at Wal-Mart for $3. Seems to be the same one as the higher priced versions. Green **** not a blade.
Old Nov 16, 2005 | 09:01 AM
carl a's Avatar
carl a
j.c. whitney sells the blade,thats what i use ,open the blade and current stops,keep it open while cars not in use,,with the **** type i had ''making & breaking'' causing alarm to go on and off when trying to disc,at shows,,so i went with the blade type----------------------------------------------------------------------------
Old Nov 16, 2005 | 09:18 AM
SharkAttack's Avatar
SharkAttack
I have the ****/screw style connected right at the battery. It came with the car and I use it every time the Vette is tucked-in for temporary slumber.
Old Nov 16, 2005 | 09:22 AM
Buzzardz_vette's Avatar
Buzzardz_vette
Just bought the blade type at Advanced Auto. I love it. Never was comfortable with the screw type.
Old Nov 16, 2005 | 10:17 AM
jimvette999's Avatar
jimvette999
Blade type here also. Mounted just to the left of the emerg. brake console behind and below my right elbow as I sit in the drivers seat. Niether the seat back nor my arm ever hit it. The arm rest cushion conceals it from view and I can take the blade out completely if I want when off. The stub the blade goes into sticks out about an inch through the carpet. I dipped the blade in black liquid plastic to cover the red.
Jim
Old Nov 16, 2005 | 11:11 AM
Scottys78's Avatar
Scottys78
Old Nov 16, 2005 | 02:45 PM
guppie's Avatar
guppie
St. Jude Donor '08
I bought the racing style and mounted it behind the drivers seat, that way I don't have to move everyhting in the storage area. You T-Tops and such
Old Nov 16, 2005 | 08:27 PM
ZL1powr's Avatar
ZL1powr
I have one on my 67 camaro located in the pass side back up light lens. Easy to access from the rear and I used a spare lens so I could easily put it back to stock if I wanted.
Old Nov 17, 2005 | 06:06 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Scotty, I believe you have your disconnect on the wrong side of the battery. I have the same style and the instructions (if I remember correctly) had it mounting on the negative side, hence the black (neg.) colored ****
Old Nov 17, 2005 | 06:20 AM
BrentDev's Avatar
BrentDev
I have no idea....but am interested in the responses.
And have to say just how much I love your car.
Too bad I wasnt the Mega Millions winner the other night.....
Old Nov 17, 2005 | 08:40 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I used to have one like Scottys78
I have a rotory type mounted just below the drivers side bumper. It's so nice to be able to just flip the switch rather than;
open the door
move the seat forward
move the T-Tops
open the cover
wedge my hand in between the sharpp edges of the battery box and the battery
unscrew the stupid little ****
dig the **** out of the bottom of the battery box when I unscrew it too far
put the stupid **** back into the stupid cable
close the battery box
move the seat back
Old Nov 17, 2005 | 09:39 AM
Twin_Turbo's Avatar
Twin_Turbo
Keith..tell us how you relly feel about it
Old Nov 17, 2005 | 05:36 PM
Techno's Avatar
Techno
Don't know what they're called or where I got them but the battery clamps themselves are quick release no tools needed.
Looks like a standard top post clamp but has a knurled nut and a cammed lever for clamping it.
Flip the lever up and the clamp is loose enough to slip right off. Push it down and its clamped on without stretching the lead terminal.
To Battery Cut Off Switch
