40 hours to remove and replace front clip
Old Nov 17, 2005 | 05:25 PM
kramek's Avatar
kramek
Default 40 hours to remove and replace front clip
Hello All,
A body shop quoted me 40 hours labour to remove the old front clip (which is a 73) and replace it with a one piece 72 frontclip. It includes putting on the correct bumpers and brackets. Does this sound about right ?
Thanks in advance
HK
Old Nov 17, 2005 | 05:26 PM
tmoneymoney4's Avatar
tmoneymoney4
i dunno but i did the math on that labor at $80 an hour, and thats not pretty
Old Nov 17, 2005 | 05:30 PM
Twin_Turbo's Avatar
Twin_Turbo
It's pretty hard to judge. I've done it a few times, the removal is hard to judge how it will go, sometimes it comes off real easy and sometimes not. I pulled mine off in about half an hour and one of my buddies (a 73) in about an hour and that was with a stubborn frame extension and rad support (someone welded it in palce, it was the wrong one for his year) but I could see it taking a couple of hours to remove it if there are problems along the way (before people think I just pulled the clips off, no I didn't both came off without any damage at all). Properly fitting the new one isn't that much work as far as positioning it properly and bonding it on, however getting all the seams right could take some time.
Why not DIY?
Old Nov 17, 2005 | 05:57 PM
71rdster's Avatar
71rdster
If there is no attempt to salvage the clip being removed then there is only a couple of hours involved in removing the old clip. Not being a professional, I don't think that I could properly align and mount a 72 clip with bumpers, grills, etc. in 40 hours. But I would think that it was a reasonable quote from a professional. Big-G want to jump in here with your insight?
Old Nov 17, 2005 | 06:03 PM
SteveG75's Avatar
SteveG75
Well, all the front end brackets have to be changed to go from the rubber bumper to chrome.If anything, I would say that could be on the low side.
Old Nov 17, 2005 | 09:23 PM
big_G's Avatar
big_G
We charge 30 hours for same year replacement. Some extra time will be required to adapt bumpers and wiper door areas. 40 hours may be a bargain indeed. BTW, our labor rate is $48...This is body labor only, no paint time in estimate. G/L
Old Nov 18, 2005 | 02:53 PM
kramek's Avatar
kramek
Default thanks for your comments
Thanks al for the advice.I believe the guy will do a good job having seen some of his other work. I'm having them do it while an insurance claime is underway. I wasn't planning on doing this now but as long as itsin the shop might as well.
HK
Old Nov 18, 2005 | 03:09 PM
Scottys78's Avatar
Scottys78
good luck
Old Nov 18, 2005 | 04:57 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Originally Posted by Twin_Turbo
Why not DIY?
To 40 hours to remove and replace front clip
