Engine Serial Number
Old Nov 19, 2005 | 03:31 PM
wmm1955's Avatar
wmm1955
Default Engine Serial Number
I just recently got my hands on a 73 coupe that I am going to rebuld and would like to know where the location of the engine serial number is. It's suppose to an L48 according to the cars VIN #. There are a few things that don't look just right about the engine I wanted to verify if the engine number matches the car VIN number.
Old Nov 19, 2005 | 04:04 PM
marshrat99's Avatar
marshrat99
The VIN should be stamped on the front of the engine block, on a small pad located just below the passenger side head, above and behind the water pump. It might be covered with gunk and need a good scrubbing to read.
Old Nov 19, 2005 | 04:24 PM
wmm1955's Avatar
wmm1955
Thanks marshrat99. Thats where I thought it was and there are some numbers and letters located there as two lines. Neither one of the lines of charcters/numbers make sense. One set is 9 characters long and the other is only 8 characters long. I thought the engine serial number was 11 characters long. The first 7 numbers should be the sequential production number followed by an F or T that says where it was made and then the next 3 characters gives the trans and carburator types. Am I wrong about this?
Old Nov 19, 2005 | 06:33 PM
LYLE's Avatar
LYLE
You should see only 13s then the last six numbers of the VIN 4XXXXX
The build date VXXXX no year then CKZ 4speed CLA auto unless it is a Calif. car. The carb. matches the three letter code.
Old Nov 19, 2005 | 07:39 PM
wmm1955's Avatar
wmm1955
Not sure I follow what you wrote so here are the 2 sets of numbers I pulled from the passenger side front of the engine block: V0524FRC CEF179423
Can you decipher the above?
Old Nov 19, 2005 | 11:17 PM
DR.Jay's Avatar
DR.Jay
Try this link
http://www.nastyz28.com/sbchevy/sblock.html
DR. Jay
Old Nov 19, 2005 | 11:31 PM
LYLE's Avatar
LYLE
I can tell you it is not the original motor installed in your 73.
Old Nov 20, 2005 | 09:33 AM
LT4Coupe's Avatar
LT4Coupe
The V (in V0524FRC) indicates that the engine was assembled
in Flint, MI. The 0524, indicates May 24 assembly. The suffix FRC
is a little confusing. The suffix was two digits up to about 1969.
Around 1970 the suffix changed to three digits (similar to yours).
However, the first character was usually a C (for car)......not F.
The second series of numbers (CEF179423) usually starts with a number (not a letter).
The number represents the GM Division.
The second character is also usually a number indicating year
of assembly. The third character indicates assembly plant. F usually
indicates Flint. However, your sequence starts with CE instead
of the two numbers. CE possibly = Crate Engine??
The last 6 numbers usually represent the last 6 numbers on the
vehicles VIN
I'm sure others on this forum will be able to shed more light on this
for you.
To Engine Serial Number
