Ok so I used my trusty multi-meter and concluded that my battery is pulling around 130 milli-amps when nothing is on and the doors are closed, etc. I know that this is a very broad question, but what do you guys think could be the problem? I'm going to try the fuse-pull thing tomorrow, but any ideas?
130ma isnt a huge draw but could possibly be your clock and if you have an aftermarket radio they will draw some current saving your presets. Also do you have an alarm?
My clock doesn't work, does a non-working one really draw that much current? I do have an aftermarket radio but i tested and it draws very little. The car did have an alarm, but I took it out last night so it shouldn't be an issue any more.
Depends on how it died. Mine became a large resister and was/still is drawing current. Another souces could be a short to the frame on +12 hot side. If its not killing the battery its probably not worth worrying about.
My daily driver sits for weeks at a time and the alarm kills the battery. I put a battery disconnect switch I got from west marine for 30 bucks in it. It has one of those big red keys. Its a great theft deterant, and is required in some racing leagues Oh and I haven't had a dead battey since.
