Replacing a power window motor
Old Nov 20, 2005 | 09:37 PM
NJAnthony's Avatar
NJAnthony
Default Replacing a power window motor
Greetings... my car was delivered to me today, and much to my dismay, my passenger window was rolled down. I hopped in, she started right up, but when I pressed the button to roll up the window, I noticed my battery gauge show that it was trying, but the window did not move and no noise was made. I tested my driver's side, and it worked properly.
A few months ago I noticed my window having trouble going up and down, and after 30 years, I just assume the motor is shot.
Is there anything special I need to know about replacing the motor? I see some window motors for r/h on a 75 on Ebay, but are there any special parts I need, or is it a direct swap?
Any tips?
Thanks!
Anthony
Old Nov 20, 2005 | 09:50 PM
surfshark's Avatar
surfshark
Someone will chime in here I'm sure on this...but i can't remember if the battery gauge will show any activity when the power window switch is bad. I replace the switch on my Mom's 'Vette back in '83 and I can't remember. It was an easy fix though if that's your problem.
Old Nov 20, 2005 | 09:54 PM
big_G's Avatar
big_G
Try closing the door while you are operating the switch. The window may just be stuck. The ammeter moving says the motor is drawing current. You may have to close the door with a little vigor to un-stick the motor...G/L
Old Nov 20, 2005 | 09:58 PM
NJAnthony's Avatar
NJAnthony
I hoped this would work, but no luck I opened and closed the door a few times, tried with the door both open and closed. No sound or movement what-so-ever, but I did get a small dim on the interior lights, so it is drawing power.
Anthony
Old Nov 20, 2005 | 10:28 PM
wcsinx's Avatar
wcsinx
If you're getting a current draw, I doubt very much that the motor is bad. More likely you just have a window/gears bound/stuck.
Old Nov 21, 2005 | 10:06 AM
NJAnthony's Avatar
NJAnthony
Are these located with-in the window motor or is this something I can find by removing the door panel?
I am at work, or I would look into the hanes manual and check myself
Old Nov 21, 2005 | 10:24 AM
wcsinx's Avatar
wcsinx
Both, if your C3 is like so many others, that white grease on the tracks has dried out into a sticky mess. You've got to pull everything out, then degrease and regrease. It's not a difficult job. It's just time consuming.
It's not in there.
Old Nov 21, 2005 | 10:41 AM
NJAnthony's Avatar
NJAnthony
It's not in there.
Well, I am glad I asked
Thanks for the help, I will check it out.
Old Nov 21, 2005 | 11:02 AM
wcsinx's Avatar
wcsinx
That's what the forums are for.
By the way, by "both" I meant that there's grease on the tracks and rollers and grease in the gear housing attached to the motor. And it was all totally dried up on my car.
I hit the tracks and rollers with degreaser, scrubbed and cussed at them then relubed with white lithium grease. Then I opened up the gear housing, wiped out all the old grease and repacked with wheel bearing grease. Now my windows fly up like you wouldn't believe.
Old Nov 21, 2005 | 12:27 PM
NJAnthony's Avatar
NJAnthony
Hopefully I will do the same. Any recommendations on degreaser or grease? Just standard stuff?
Old Nov 27, 2005 | 03:24 PM
NJAnthony's Avatar
NJAnthony
Just wanted to say thanks for everyones help. I am glad I didn't waste my money on another window motor.
I took apart the door, removed the motor, greased the rails and gears, gave it a good knock or two to make sure it wasn't stuck, but it back together...
It worked!
Thanks 'vette forums, you saved me again!
Anthony
To Replacing a power window motor
