reglueing t-top trim
Old Nov 22, 2005 | 08:23 PM
chris75stingray's Avatar
chris75stingray
Default reglueing t-top trim
i took the trim off before i stripped my car. now what do i use to reattach it ? are the screws and rivits enough to hold it or do i need something like the glue that was originaly in there?
Old Nov 22, 2005 | 08:25 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Need the glue all the way around to seal. 3M weatherstripping adhesive is the stuff you need. Comes in black & yellow as I recall. I think yellow was factory original if you care, but that is not as easy to find as the black.
Old Nov 22, 2005 | 08:28 PM
chris75stingray
i'm talking about the stainless steel trim.
Old Nov 22, 2005 | 11:45 PM
Ric's80_4sp's Avatar
Ric's80_4sp
Use something like 3m caulk strip..if not you will have a nasty water leak for sure.
Old Nov 23, 2005 | 04:43 PM
chris75stingray
thanks, at first i couldn't figure out why i should be sealing it, but i just looked at them and saw how they mounted. (have had the car apart way too long)
To reglueing t-top trim
