power steering cylinder
Old Nov 23, 2005 | 09:20 AM
1Z87L8's Avatar
1Z87L8
Default power steering cylinder
is it better to rebuild it or buy one ready to bolt on?
any thoughts are appreciated.
Old Nov 23, 2005 | 09:23 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Either way. I have had better luck rebuilding the steering cylinder than I have had building the control valve. The cylinder is an easy rebuild. Go for it.
Old Nov 23, 2005 | 01:10 PM
texaswilkins's Avatar
texaswilkins
Buy the rebuilt ones. Mine both needed more parts than come in the kits so I had to replace them anyway.
Bill
Old Nov 23, 2005 | 05:36 PM
worship79's Avatar
worship79
Used the kit, removing the cylinder from the steering arm is the hardest part
Old Nov 23, 2005 | 06:20 PM
NHvette's Avatar
NHvette
I tried the kit ... still leaks. The piston/shaft must be scored.
Well, I can say that it doesn't cost too much to try.
If that doesn't do it - then I would say "new".
To power steering cylinder
