Cable junction block
Old Nov 26, 2005 | 12:51 PM
TPI BOY's Avatar
TPI BOY
Default Cable junction block
As the title says, where is it located
and what is hooked up to it. 1975.
Old Nov 26, 2005 | 02:32 PM
TonySinclair's Avatar
TonySinclair
Need more specifics. What assembly?
Old Nov 26, 2005 | 04:46 PM
TPI BOY's Avatar
TPI BOY
It's for a 1975 Small Block
They say in the Ecklers Catalog it's
mounted on the drivers side firewall.
Old Nov 26, 2005 | 08:49 PM
TPI BOY's Avatar
TPI BOY
No one knows?
Old Nov 26, 2005 | 10:05 PM
TonySinclair
Here you go:
http://www.ecklers.com/product.asp?p...dept%5Fid=1107
That's where all the underhood positive/hot (+) cable leads attach. I tapped into it to run my electric fan.
Old Nov 26, 2005 | 10:35 PM
TPI BOY's Avatar
TPI BOY
Does the starter alternator hook up
to this?
Old Nov 26, 2005 | 11:01 PM
TonySinclair
to this?
Starter or alternator? I believe there is one wire from the alternator and one wire from the starter. Not 100% sure, though...I don't have my car and/or wiring diagram in front of me.
Old Nov 27, 2005 | 06:48 PM
TPI BOY's Avatar
TPI BOY
I have looked all over for it, where
is it on the 1975 . They say it's on the drivers
side firewall, I have looked and still can't find it
Old Nov 27, 2005 | 06:50 PM
Twin_Turbo's Avatar
Twin_Turbo
On the 82 it's in the drivers side battery box, next to the battery (remove the tray)...isn't it there on the 75 also???
Old Nov 27, 2005 | 06:56 PM
TPI BOY's Avatar
TPI BOY
Just looked still can't find it.
Old Nov 27, 2005 | 06:58 PM
Twin_Turbo's Avatar
Twin_Turbo
Are you sure it's not there? In the battery box, on the outside/wheel side of the box, next to the battery. It's hard to spot ..might want to trace the wires and feel in there..depending on year some things hook up there but the alternator charge wire should be one of them.
Old Nov 27, 2005 | 07:22 PM
TPI BOY's Avatar
TPI BOY
So what you are saying it's on
the outside in the rear wheel
next to the battery box, is that
right? Thanks for all your help
Old Nov 27, 2005 | 07:46 PM
Twin_Turbo's Avatar
Twin_Turbo
no, it's inside the car, open the rear storage compartment lid and remove the tray to expose the battery, the battery is sitting in the fiberglass rear floor part, the battery box. Now look on the wheel side of the box, not the driveshaft side....the junctionblock should be there..damn how to explain properly...here look at this pic, see where i drilled the 2 holes? Then over to the right, the side that isn't visible in the pic..that's where it should be
Old Nov 27, 2005 | 07:56 PM
TonySinclair
On my '74, it is located on the driver's side (inner)fender, under the hood, tucked away next to/behind the windshield washer bottle. It is fairly high up on the inner fender, underneath the fender "overhang" (for the lack of a better word). If you are casually looking for it, you will not see it. You have to have a flashlight or shoplight. It is almost equidistant between the front of the car and the firewall. Follow the bundle of wires coming from the headlights and you'll run right into it.*
*I'm assuming '75 is the same as '74...
If "Bubba" has worked on your car previously, this part may have been removed and replaced with splice connector's or, in true Bubba fashion, a wad of electrical tape.
Old Nov 27, 2005 | 08:01 PM
TPI BOY's Avatar
TPI BOY
Thanks for your help, but it's not
their. I have looked and felt, took battery out,
but no luck. could the 1975 be in a different
place? Your picture is different then the 75.
Again thanks for you time and help.
Old Nov 27, 2005 | 08:14 PM
TonySinclair
It's not in the battery box in a '75. See my post above.
Old Nov 27, 2005 | 08:24 PM
TPI BOY's Avatar
TPI BOY
Yes, I did read your post, thanks I will check
it out, it's to dark now, I have a car port, I hope
I find it. Thanks for everyones help
Old Nov 28, 2005 | 03:48 AM
Twin_Turbo's Avatar
Twin_Turbo
On older cars the horn relay is the 12v bus also, forgot the changeover year
To Cable junction block
