Single plane intake under stock hood?
Can I fita single plane intake under a stock hood? From all I have read, it seems I would need a dual plane....But some f the nicer top end kits are all single plane. Can I fit a single plane? If so, how? Would a drop base air cleaner work?
Shane
Shane
Shane
The 73-79 med. rise hood allows the Victor Jr. single plane, RPM dual plane & others on SB w/ aftermarket dropbase filter & Holley.
Whether you need single or dual depends on the setup like C.I., cam, trans., rear gears, intended usage etc.
Cruise-In IV Veteran
Weiand Stealth intake might fit
Features:
# High rise/dual plane design
# Idle-6800 RPM power band
# No EGR provision
# Square flange carburetor mounting
# HEI will clear. Alternator bracket may require modification.
# Height: Front is 4.18'', Rear is 4.50''.
jegs p# 925-8016
Features:
# No EGR provision
jegs p# 925-8016
